Results 1 to 12 of 12
Thread: ISTA-P "Please install and register the ISPI"
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    I have ISTA-D installed and working just fine. I found ISTA-P here: https://mega.nz/#F!5pIW1DyY!jYoL2TxwI1WyWfuudfN4nA and ran the full installation. When I try to open it I get this error and I cannot find any posts references how to fix it.
    "Please install and register the ISPI Admin Client. Starting ISTA/P is not possible".
    Any help is appreciated.
    Thanks.
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    so I'm not the only one having this problem. From what I understand the ISPS client is a seperate program which needs to be installed. But I can't find it anywhere.
    BTW, I also find the install location (ProgramData) a bit strange for ISTA/P
    check out this page: http://obd2-diag.blogspot.de/2016/04...-download.html
    I'm still working on the problem but this appears to get close to the solution - hopefully.
    ISTA-P is running.
    PM me if you need any help.
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    Wokke, Great job how did you get it to run?
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    Quote Originally Posted by wokke View Post
    ISTA-P is running.
    How did you get it to work? I have installed ISTA/P version 3.65 and ISTA-D. My ISTA-D is work perfectly, but my ISTA/P when I open ISPI Admin Client and run the "Health Check" I get an error ISPi Client central server can be reached( it has a red X) . If I try to open the BMW.ISPI.TRIC.ISTAP.TrayApplication.exe from folder c:\programData\BMW\ISPI\data\TRIC\ISTA-P\BMW\Administration\TaurusAdministration
    I get an error "the version 3.65.0.500 of the ISTA/P Application that you are using is no longer valid".
    Thanks in advance for your help.
    Jul 2018
    Northern California
    2004 BMW 525I
    im new to this kind of stuff but what i am wondering is because im mainly concerned with using my k+dcan cable to read any codes my car maybe throwing as well as to watch the different sensors and see if i can see a problem of any kind no real coding or anthing like that is there a dumbed down version for that or is it pretty much all the same no matter what you want/ dont want to do with it?
    Jul 2014
    Louisiana
    1995 M3
    Brett, I did this two years ago and I remember having to do something...I'll see whether I can find the notes that came with the software that I had purchased.
    May 2018
    Chicago,IL. USA
    2006 BMW 750i
    Quote Originally Posted by NolliM3 View Post
    Alright I guess I'm close to understanding istap. Download ispi admin client 4.0.2
    Download BMW Loader Istap v6.3
    The first is to register while the other is to load istap.
    Feb 2020
    Uk
    BMW X5 e70 lci
    Any one have any look with this
    Apr 2021
    Lagos, Nigeria
    BMW E60 2009 528i
    ISPI Admin Client Error
    ISTA-P is running.
    Hello, I have gotten INPA, ISTA-D to work correctly.
    I have also installed ISPI Admin Client. However, when I launch ISTA/P it, I get the error "The device is not registered in the ISPI Admin Cleint. Starting ISTA/P is not possible."
    When I attempt to launch ISPI Admin Client, it fails to connect to BMW Group and returns with the error"ILAC-007 Failed to reach Server".
    Please advise, what can I do?
    Aug 2023
    accra,greateraccra, GHANA
    2008 BMW 5 SERIES
    Ispi
    Quote Originally Posted by Braymond141 View Post
    Thanks.
    please can i get a link to download the ISPI ADMIN CLIENT
  1. Window Guide Rail Rubber - Installed and awaiting the test of its first rain
    By wcampbelliv in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-31-2016, 09:57 AM
  2. I wish I'd have gone and registered the car today...
    By vtgti in forum 1975 - 1983 (E21)
    Last Post: 05-11-2007, 03:32 AM
  3. Replies: 3
    Last Post: 08-26-2005, 10:12 PM
  4. Replies: 4
    Last Post: 04-14-2003, 08:53 PM
  5. PLEASE READ (and get the word out)
    By CMT in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-07-2001, 09:23 AM
