Results 1 to 14 of 14
Thread: STEERING WHEEL WOBBLE AT 50 mph
    Mar 2010
    Vancouver, BC
    1990 BMW 850i, 1976 Nova
    been happening for a while now... while normal acceleration upon hitting 50 mph the steering wheel wobbles alot... after 50 the wobble stops... Just had my 8 serviced at a very good local mechanic, turned front rotors, repaired bearings on top of front passenger shock, balanced both wheels and 4 wheel alignment yesterday, but today still wobbles...
    I was told that my steering box had alot of "play", could this be the culprit? but why only at a certain speed??
    "...i haven't taken leave of my senses Bob, I've come to them..." -- Ebenezer Scrooge
    Orlando, FL USA
    Have you checked the usual places, Star? Upper and lower control arm bushing for signs of cracks/tears? Do you know if your front tires may have flat spots?
    Sunny Cali,
    6.5 second 69 Camaro
    Upper control arm bushings.
    Mar 2010
    Vancouver, BC
    Quote Originally Posted by 8eights View Post
    of course all of the UCA and associated bushings were checked and re-checked... all good and no play...
    thus the mystery...
    Quote Originally Posted by ChrisFuture8 View Post
    no tire anomalies were noticed by the mechanic...
    Sunny Cali,
    Were the uppers preloaded before installed unless they are Spherical?
    Mar 2010
    Vancouver, BC
    i was willing to change the UCA but the mech said that it was NOT required... in fact, i already changed them about 6 years ago...
    Sunny Cali,
    Try putting your stock wheels on the front to see if it goes away, If it doesn't go away, it's a bushing, Can you tell which one is shaking?
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Control arms. You can check them visually, but you need a second person. Have your helper watch the front wheel as you drive at about 15-20 mph and come to a complete quick stop. If the wheel moves toward the back of the wheel opening, you have control arm issues.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Mar 2010
    Vancouver, BC
    Quote Originally Posted by TxGR8White View Post
    yes that sounds like a very good test!! thank you... ill even have it video taped...
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Most likely control arms but if all else fails to provide a fix, check your rims. I had one that was slightly out of true and, even thought it balanced ok, it produced similar symptoms.
    '91 850i 6sp (mint) (sold)
    Nov 2012
    OC, CA, USA
    '97 840Ci, '02 X5 4.6is
    Everyone here will point you to UCAs and other suspension components... But actual source of vibrations is always you wheels.
    Good control arms help to damp those vibrations through rubber bushings. If your bushings are worn out you will heave excessive movement of the suspension components allowing harmonic vibrations to multiply at certain conditions and become noticeable. On the other hand some people may also suggest to replace UCA bushings with spherical ones, but it will only hide the problem by stiffening the suspension - the whole car becomes a huge damper.
    So, if you don't have any play in suspension - take a closer look at your wheels and tires. Even a good looking tire can have internal cord damage. If you can, swap your front wheels with known good ones to test.
    WBR, Tony
    Toronto, Canada
    BMW 850CSi
    Quote Originally Posted by starship1701a View Post
    This is the key phrase here...”6 years ago”. You’re lucky to get 1-2 yrs with the stock UCA bushings before they get soft and cause the dreaded wobble! But they’re only a couple bucks and 30 min/side to replace...
    Jan 2014
    London, UK
    Bmw 840
    I Hope Timm won't mind however check the attached link. Lots of useful stuff.
    https://www.meeknet.co.uk/e31/E31_Shimmy.htm
    1998 e31 840ci Sport, Individual. 2008 Aston Martin DB9. 2016 4.4 SDV8 Range Rover Vogue.
    1959 Triumph Bonneville, 1969 T120R Triumph Bonneville, 1975 T160 Triumph Trident, 1990 Harley Davidson Fat Bot Grey Ghost, 2009 Triumph Bonneville 50th Anniversary model. 2014 Suzuki Gladius.
    Mar 2010
    Vancouver, BC
    Quote Originally Posted by cartoonz View Post
    ok yes... my front pass rim had a dent on the inside edge i was told, he tried to right it as much as he could them balanced both rims...
    i feel its my rim/brakes as well, but not discounting the UCA bushings...
    thank you!
    Quote Originally Posted by 1959terry View Post
    wow! tons of interesting stuff!!
    thank you
  1. Replies: 41
    Last Post: 05-25-2014, 10:56 PM
  2. Steering wheel shakes at 60+mph while braking
    By e36bm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2009, 04:49 PM
  3. Steering wheel vibration at 60~mph (not tire balance)
    By rebs in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2009, 02:39 AM
  4. Help steering wheel shake at 100 mph
    By jhstealth in forum 1991 - 1999 (E36)
    Last Post: 11-27-2007, 12:03 AM
  5. Steering wheel shakes at 50 MPH?
    By apache5 in forum 1996 - 2003 (E39)
    Last Post: 09-20-2007, 10:43 AM
