Results 1 to 9 of 9
Thread: Stumped: Right side low beam
    Apr 2018
    CT
    2008 E93
    Hey guys,
    Long time lurker. First time poster. I own a 2008 E93 which has been great (until lately!). I've been having some issues and i'll break it down below. Have searched for days but unable to find an answer (though am leaning towards FRM--- just want to confirm)
    Right side low beam xenon has been out for a few months due to a ballast and more recently water leaked into my left side as well, leaving my vehicle without any headlight function! I decided to tackle it this weekend and basically replace everything. I removed both headlights and replaced the bulbs and ballasts on both the left and right side (as expected, ballast water damage). I also examined the AHL modules and they looked fine. I then plugged them back in (right headlight into right side, left into left side) and only the left side was functioning properly. ????
    I then took the right headlight and plugged it into the left side - worked. Plugged the left headlight into the right side - did not work. Confirmed that the lights themselves are functioning and work fine on the drivers left side, but neither work on the right side. Im thinking this is either due to the connector (although my turn signals + halos work on the right side) or the FRM has shut down the circuit.
    I have mycarly/icarly/bmwhat app which I used to scan the codes. This is what I get
    Right fog light, E90 M3: day time running right defective, PL3 from 7/14 and (SA5A1 or SA896): Brake light broken right
    CODE: 00A8AF
    Low beam broken right
    CODE: 00A8AB
    >>> I can confirm that my right DRL and right brake light are fine.
    Disturbed communication with StepperMotorBox left / defective SMC left
    CODE: 009CBF
    >> the left side AHL works fine (i can confirm that)
    Thoughts? Me thinks signs are pointing towards FRM needs a circuit reset
    Apr 2018
    CT
    2008 E93
    If any coders in hartford CT area... let me know!
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    check your fuses. I believe they are independently fused.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Apr 2018
    CT
    2008 E93
    Quote Originally Posted by legoman67 View Post
    forgot to mention; checked both 45A fuses and they're intact.
    Apr 2018
    CT
    2008 E93
    Update: learned how to use toolset32 and got the necessary equipment. Showed 127 short circuit faults. Reset the counter and everything is fine now.
    Jun 2015
    Racine, WI
    BMW X5 3.0i
    So the computer shut everything off when it detected the water based shorts to prevent more damage and you had to manually reset before it would work again?
    wethersfield ct
    330xi
    my 2003 has a left low beam that occasionally wont come on, if I flip the lights on and off a few times or shut the car off then start it back up again it works fine. any ideas??
    Jun 2015
    Racine, WI
    BMW X5 3.0i
    Ignition switch
    Sent from my iPhone using Tapatalk Pro
    Jun 2017
    Denver, CO
    '08 E90 335xi manual
    Quote Originally Posted by noturbos View Post
    Have you tried the forum for your car?
    Are you gonna eat that?
  1. WTB- Euro Ellipsoid drivers side low beam bulb cover.
    By schwarzIIe36 in forum BMW Parts Wanted
    Last Post: 04-11-2005, 02:59 PM
  2. WTB: E34 Driver's Side Low Beam Headlight
    By jettin96 in forum New York / New Jersey / Connecticut
    Last Post: 03-16-2005, 11:36 AM
  3. WTB: Left Side Low Beam Lens or healight unit for E34
    By shady in forum BMW Parts Wanted
    Last Post: 05-15-2004, 10:17 PM
  4. Passenger side low beam Bulb Keeps Blowing out !!
    By atlantisvip in forum 1991 - 1999 (E36)
    Last Post: 02-22-2004, 09:46 PM
  5. Passenger-side Low Beam Failure w/ ZKW&HID
    By n2oo1 in forum 1991 - 1999 (E36)
    Last Post: 02-18-2004, 12:20 AM
