Results 1 to 12 of 12
Thread: E70 Reset short circuit in FRM
    Sep 2013
    Calgary, Alberta, Canada
    Only BMW's for last 30 y
    Hi,
    Recently I got problem with right side tail light. Simply does not work and error shows short circuit.
    By using INPA I found that FRM II module installed, but description file loaded FRM_70.
    When I tried to use file FRM_70 I did not find
    RESET_KURTZSCHLUSS_SPRRE
    and does not work also
    STEUERN_RESET_KURTTSCHLUSSABSCHALTUNG
    I tried to use in Tool 32 FRM_87 file and Job " reset kurzschluss_sperre " and got
    " error ecu subfunction not supported invalid "
    Will very appreciate any advice how to solve this problem,
    Thank you.
    Jul 2004
    Houston, TX
    36 Cylinders
    Post the FRM_70.prg result from info job. This is to see the version of your file.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2013
    Job listing in FRM_70 file
    These are first 5 pictures from job listing in FRM_70 file.
    Sep 2013
    Job listing in FRM_70 file second part.
    These are last 5 pictures from job listing in FRM_70 file.
    Jul 2004
    Houston, TX
    36 Cylinders
    Run the info job from 1st pic
    -Abel
    Sep 2013
    FRM_70 info job for E70 X5
    Here it is.
    Jul 2004
    Houston, TX
    36 Cylinders
    download and place this file in C:\EDIABAS\ECU\ overwriting the old one. Then try again.
    -Abel
    Sep 2013
    Good progress with new file FRM_70
    Good progress, thank you.
    New file contains job:
    _reset_kurzschluss_sperre.
    I successfully erase all 3 shorts. After immediately check with INPA and ISTA. Both did not show any fault codes.
    But when I perform visual check I found out that it does not work and fault codes appears again.
    I repeat erasing and check with another person.
    After erasing light works just about 10-15 seconds and gone.
    I repeat erasing and check couple times more, but result still same.
    2 codes related these light appears again and again, see picture.
    Now is a good question, what to do?
    I have originally installed FRM module from this car. It was replaced 2 years ago because all window stop works.
    Maybe try it, but need to erase fault codes in FRM for window?!
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    It probably means you still have the short circuit and need to fix the wiring
    Giftschrank Projekt
    Sep 2013
    But if it real shortcut it should not works even 10 seconds?
    Quote Originally Posted by enda320 View Post
    Sep 2013
    Reset window fault code in FRM 3 E70
    Does anybody know which code related to window in FRM 3?
    I would like to reactivate old one from this car.
    Sep 2013
    Thumbs up Problem with tail light E70 - solved
    Hi,
    Enda320 you was right.
    I checked the counter with "STATUS_LAMPEN_KURZSCHLUSS_COUNTER" and find exact same 2 errors that before. I placed picture in my previous post.
    Next I decided to check physically what is go on in light assembly. Thank you Enda320, this is your advice.
    In right assy I did not find any problem, looks like just installed brand new. But in middle right side ( 5th door ) I found lots of dirty spots. It is pain in your u........ to remove it from door but it worth. This is show me that it has leaks. I cleaned with contact cleaner and tested .
    Result wonderful, no more short related errors and everything became to properly work.
    After I put everything back, indeed seal properly.
    So far everything good.
    Thank you everybody for response/advice.
  1. Software Needed for an E70 with Short Circuit Fault
    By wavejam in forum Diagnostic Software
    Last Post: 06-07-2016, 10:37 AM
  2. Reset short circuit of smc tool32
    By melonidas in forum Lighting sponsored by BAVToys
    Last Post: 11-14-2014, 02:38 PM
  3. short circuit somewhere in my car need help
    By frankliiin in forum 1991 - 1999 (E36)
    Last Post: 12-14-2010, 08:53 AM
  4. short circuit somewhere in my car need help
    By frankliiin in forum Forum Software Questions & Suggestions
    Last Post: 12-14-2010, 02:03 AM
  5. help short circuit in armrest
    By fishboy1 in forum 1996 - 2003 (E39)
    Last Post: 05-26-2007, 02:45 PM
