Results 1 to 9 of 9
Thread: INPA Error IFH-0006: Command not accepted, Help needed
    UAE
    Merc R129, E31, Jag XKR
    Hi Guys
    I purchased the diagnostic laptop from a member and Im having problem with INPA on my 98 E38 V12 and 95 E31 V12. I cant seem to access the DMEs but can access the EML
    Laptop: Lenovo x131e
    Inpa:
    Im using these cables
    I keep getting this once i try to access the DME on both my V12s
    and then
    Any help would be appreciated
    "Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
    The Netherlands
    DE-spec E36 328i/M3 cab
    In INPA/EDIABAS aer pdf files that explain all the errors.
    Are you using ADS?
    IG:
    UAE
    Quote Originally Posted by MParallel View Post
    Are you using ADS?
    Ill look into the PDF files,
    I dont think this, the link for the cable says BMW INPA/Ediabas K+DCAN USB Interface TO OBD OBDII OBD2 Car Diagnostic Scanner Tool Cable
    I posted pictures of the cables I got, guessing i need to order another set of cables?
    Jul 2004
    Houston, TX
    36 Cylinders
    I haven't done the research whether the V12's DMEs are K line or L-line?
    If they are L-line, then you need ADS interface, or an ICOM.
    The K+DCAN can do K line diag just fine.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    UAE
    I can read the EML and gearbox but not the DME
    Can you recommend a ADS cable thats has a USB end since my laptop doesn't have a serial port?
    Jul 2004
    Houston, TX
    36 Cylinders
    I have not seen an ADS interface actually work on USB. Some claim to work on USB, but I'm still waiting for one to say, yes, I connected to an L-line module through ADS on USB!
    An alternative option is ICOM interface (significantly more money), which will work fine with newer laptops and L-line modules. It connects with Ethernet or wifi to the laptop.
    But be very careful with the Chinese clones. Some of them are very poorly made. Do your research, or ask.
    -Abel
    The Netherlands
    Just to add, I finally got confirmation from Do It Auto that their USB-ADS interface does not work without a serial port.
    So AFAIK, ADS still requiers a serial port laptop or fancy diaghead (Icom, GT1).
    IG:
    The Netherlands
    Here's from the FAQ doc located in C:\EDIABAS\Doku\English
    1.3 EDIABAS Error 16: IFH-0006: COMMAND NOT ACCEPTED
    This error occurs if an SGBD is loaded into ToolSet and the OBD connector is being used.
    Cause 1: ODB has actually been set as interface inside EDIABAS.INI, but ToolSet uses
    multi instance with another interface, e.g. K-line. The setting for multi instance
    and the interfaces used is made inside the file TOOL32.INI, in the directory
    C:\WINDOWS (or alternatively C:\WINNT for Windows NT). Therefore the entries
    in TOOL32.INI regarding the interfaces are used instead of the ones in
    EDIABAS.INI. The use of multi-instance in the ToolSet is identified in the title
    bar, for example with “Tool32:1”, for single multi-instance.
    Solution 1: Enter the interface being used into TOOL32.INI or disable multi instance by the
    entry “No”.
    Cause 2: An SGBD using the diagnosis protocoll is loaded into ToolSet. For UDS-SGBDs
    you have to use the interface OMITEC but in the EDIABAS.INI the setting for
    the interface is
    Interface = STD:OBD
    Solution 2: Modify the interface setting inside EDIABAS.INI to
    Interface = STD:OMITEC
    The OMITEC connector must have power supply (blue blinking). If the connector is not supplied and you want to load the SGBD, you will have to use the simulation mode. You can activate the simulation mode inside the menue
    Configuration -> EDIABAS
    Notice, if you want to use the simulation mode, a simulation file for the interface
    has to exist inside the simulation directory. for further ways of solution, see chapter 1.11
    IG:
    Jul 2004
    Houston, TX
    36 Cylinders
    Odd explanation from them, because OMITEC USB cannot do L-line communication. I have one and have tried everything. Omitec desktop does ADS, but OMITEC in general are so rare and expensive, you're better off with a genuine ICOM.
    Maybe it's the same idea, but needs to be on ADS setting, with ADS interface.
    -Abel
  1. INPA Error IFH-0009 NO RESPONSE FROM CONTROLUNIT.....
    By Drexellake in forum Diagnostic Software
    Last Post: 12-10-2018, 05:16 PM
  2. INPA error IFH-0006
    By Denniz0229 in forum Diagnostic Software
    Last Post: 06-18-2018, 07:35 PM
  3. INPA error IFH-0009
    By xxxjecxxx in forum Diagnostic Software
    Last Post: 09-11-2013, 06:30 PM
  4. INPA Error IFH 0009
    By 4enjaM87 in forum Diagnostic Software
    Last Post: 05-27-2012, 11:20 AM
  5. INPA error #95 , sys-0005 , and registery. Help
    By mickaphely in forum Diagnostic Software
    Last Post: 03-11-2011, 01:59 AM
