Results 1 to 8 of 8
Thread: Horn Part Number???
    Toronto, Canada
    BMW 850CSi
    Horn Part Number???
    Hit a large piece of rubber from a blown truck tire on the highway yesterday and it broke the lower CSi spoiler clear off and both horns. What is the correct part number for the 2 horns behind the front spoiler??
    http://www.realoem.com/bmw/enUS/show...diagId=61_0964
    Is it 2 of the Low Pitch #61337163999 or 2 High Pitch #61337164000 or one of each?
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    one of each
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Not that you are particularly interested in this approach, but Hella supertones can be fitted without hacking up any wiring and are plenty loud(er) vs the stock ones even without the relay. Easy to fit off the shelf inside the nose cone plastic guide using the power steering cooler mounting points.
    What "thumbs up" really means
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Quote Originally Posted by toomanyparts View Post
    Do you have an example of this
    Mar 2011
    CT
    '97 840CI
    Yes, simple fit with angle bracket to existing studs.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    How did you do that without butchering the wiring? Just depin the factory connector and put spade connectors on it?
    CT
    '97 840CI
    Been nine years, but I believe that I used this type of female pin connector to slide onto the male pin connectors of the wiring harness.
    Then a dab of RTV silicon to close and seal the connection from the elements. No alteration to the factory harness.
  1. Part Number Request M3 95 Horn Connector
    By Das Bullitt in forum 1992 - 1999 M3 (E36)
    Last Post: 07-01-2014, 02:32 PM
  2. Replies: 3
    Last Post: 07-16-2001, 03:28 AM
  3. BMW Part Number?!?
    By Seedster in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-07-2001, 06:54 PM
  4. NE1 know the part numbers for Euro Head Lights?
    By Andrew in Atlanta in forum 1992 - 1999 M3 (E36)
    Last Post: 03-28-2001, 09:49 AM
  5. Part number for Motorsport intl. side emblems
    By Josh///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-08-2001, 10:40 PM
