Results 1 to 11 of 11
Thread: Gt4094 turbo making a few pulls
    Jan 2003
    Charlotte
    Just picked up a gopro fusion, this is my first video. Pretty stoked about just setting it up and capturing everything.
    https://www.youtube.com/watch?v=Y9V4xbQC96s
    1998 Turbo M3 Nick G tuned setting 5 934Whp 849Wtq @27.88 Psi. ignite E90 setting 6=
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    More specs on the build? T4 AR?
    Jan 2003
    Charlotte
    T4 old steed speed manifold, S50 crank with 84.5mm bore forged with completely stock head. This run was at 15 psi I need to get it on the dyno for Nick G to make adjustments to the tune
    Mar 2012
    Renton, Wa
    98 m3
    Looks slow to me
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Jan 2003
    Charlotte
    Quote Originally Posted by vollosso View Post
    Looks slow to me
    To me too! It’s pretty slow for now it’s making around 550whp
    Vancouver, B.C., Canada
    '97 M3
    So many old forgotten builds out there. Ones that inspired and taught us so much.
    PS turn up the boost
    Jan 2003
    Charlotte
    Quote Originally Posted by chikinhed View Post
    Thanks, I’ll be turning it up...
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    What happened to the fancy head?
    Jan 2003
    Charlotte
    Sitting in my garage. This is a small bore motor currently in the car so I cannot use that head. I am currently having the identical specs done on another head but for a small bore motor.
    gotta build me another 86.5 bore to use it though that motor was a beast.
    poconos pa
    e36 m3, turbo e36
    Did something happen to the old motor? That thing has seen some miles and passes if I recall correctly.
    -sold...replaced by turbo e36
    Jan 2003
    Charlotte
    Quote Originally Posted by beeasy View Post
    Yes it had quiet a few miles. I ended up cracking cylinder 3 we believe heat related. That’s the only issue with making big power on 93 octane.
  1. Any 335i in NY want to do a few pulls with a S4
    By 2001S4NY in forum New York / New Jersey / Connecticut
    Last Post: 03-14-2007, 04:07 PM
  2. Easy way to make a few bucks
    By 2K5 325i in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-29-2005, 07:55 AM
  3. Need help, Turbo making horrible noises
    By tjn182 in forum Forced Induction
    Last Post: 11-09-2004, 03:00 PM
  4. what power can an M3 turbo make?
    By nitropower in forum Forced Induction
    Last Post: 08-19-2004, 04:26 PM
  5. Technically, What Aspect Of A Turbo Makes It Create More Tq...
    By icemann633 in forum Forced Induction
    Last Post: 05-20-2004, 08:20 PM
