I'm sure there is a thread out there somewhere that touches on this, but damn if i could find it. So my apologies in advance!
I've recently installed 19" wheels on my '98 528i and now i'm looking to fill the cavernous void left by the miniature factory brake set ups. First, i'm looking to solve the issue in the rear. My intention is to install a set of M5 take offs. This is strictly an aesthetically driven mod, and i'm not expecting much if any increased performance. So, has anyone already attempted this?
In looking at the exploded parts diagrams on realoem, it looks like all I will need is the complete caliper assembly, rotor and the protective plate. All other part numbers seem to be a match. But it cant really be that easy......can it????
Love to hear from anyone who has already done/tried this.
Well. If OP has JUST SOURCED brand new E39 wheels, E60 hub swap is an assload of unnecessary pain and suffering and $ for zero short-term gain and infact would require then adapter hub rings for the wheels he has already. Not to mention its not just the fronts you'd get all involved in the rears too.
Re: the brakes...
Fronts are indeed pretty easy bolt on as Jason links to above. The rears are what require any 'real' work at all. You either need to swap the backing plates, or, cut the existing ones up, and I believe also something with the parking brake adjusters. I have never done this myself, but just know from others.
Be aware (look at pix...) the M5 brakes are big honking cast ATE mono-pistons, essentially just like a bigger version of what you have. So they don't look THAT sexy and aren't actually even THAT big, although if you powder coat or epoxy paint them, then of course you can get a little bit of bling factor going (however PC'ing your existing brakes would not look that much different!) They do have an "M" on them so there's that .
Yes they will be an 'improvement' for sure, although your existing brakes aren't probably falling short in any way, but hey, mods are mods and better brakes are always good. Most of the benefit IMO is probably coming from the bigger rotors and 'swept area' ore than piston size of the caliper.
M5 rotors are 345mm/328mm
540/530 rotors are 324mm/298mm
538 rotors are 296mm/298mm (rears same as 540)
So a 1/2 way cheapo budget brake upgrade option exists to use 540/530 front brakes which are essentially 1/2 way to M5. I'd offer you my 540 take-offs but they are running around on a friends I6 E39T already.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
2003 M3CicM6 TiAg
Former:
Thanks Geargringer.....I know the M calipers aren't much in the looks department, but I plan to do the ECS big brake kit in the front, so the comfy price point of the used M set up and fresh powder coat is what I'm shooting for. There's a guy in my area that parts out e39 M5's, so the parts are easy to come by. Also, agreed on the performance of my existing brakes "not falling short". But. I'm about due to for new rotors and pads anyway, so....eh, why not. The increased rotor size(for the look) is really what i'm after, to be honest.
Great feedback though! Much appreciated
Personally I’d stick with the 530i or 540i calipers and discs/pads
Im running 19” alloys on my 530i and they fill the gap very well IMO
Those, alongside braided brake lines and decent fluid, you’ll have great stopping power and looks to fill the wheels until you do your BBK upgrade
My car: 2002 E39 540i Sport - Japanese import - the new project!
And you do know that your front calipers are cast iron, the rears should be aluminum.
The M5 calipers are all cast iron and MUCH heavier, same for the heavier M5 rotors if that concerns you.
2003 M3CicM6 TiAg
Former:
I knew that cuz I has a set of M calipers when I bought the M5 subframe with everything attached to get the diff, driveshaft, and axles. I powder coated them and was going to put them on my car, but didn't want the extra weight so I sold them to some dude in chi town. Gave the rotors to Leo, think you might have got the backing plates. The only thing I have left is the e-brake cables.
Ha. I gave the backing plate stuff to Leo in the end too I think?
2003 M3CicM6 TiAg
Former:
I may be doing this setup on my Wagon later this summer. Another guy I know is running C6 Z06 calipers in the front with Z06 rotors, originally had E60 535 rotors on the front.
Using the Z06 rotors at a massive 14.1", I'm not sure if even a set of Volk Racing TE37s or ARC8s in a 17" diameter will clear. Using the E60 535i rotors would definitely allow the clearance, as they are 10mm smaller and that rotor is shared with the 135/335s as well.
Just some food for thought.
