Results 1 to 5 of 5
Thread: Reverse Lights Non Operational: Wire hunting
    Mar 2015
    Oceanside, California
    1997 2.8 Z3
    I recently discovered that my reverse lights haven't been working, who knows how long that's been going on.
    I drive a 97 2.8L Convertible. I've checked the boot and the connections to both lights as well as the cabling going along the boot. Nothing is out of place there.
    I've checked fuse 26 and triple checked it wasn't the problem by switching it with confirmed working fuses as well as using a multimeter to check the connection at the fuse( only place multimeter used ). After searching I found the electrical troubleshooting manual(page 201) and came to the conclusion that it would most likely be a connection somewhere around the shifter. This lead me to take apart the center console, but it seems that I can't even see the wire as it's most likely underneath the carpet somewhere.
    What I want to know is if I'm going about this the wrong way, or there's something else I could check as well. Because at this point I'd be removing the seats, the compartment behind the seats and the carpet, to which I don't know if that would even allow me to see the wire connection. This is my first time going after electrical stuff, any help is appreciated.
    Side note: My radio was having connection problems as well, but eventually lost connectivity. It got dimmer as time went on to fully cutting out and not being responsive in the slightest. All the connections to the radio when disconnecting it seemed fine, so I'd assume it has a ground problem elsewhere.
    Nov 2013
    Winter Springs,Fl
    01' 2.5i Rdstr'
    Reverse light switch on the transmission. Takes longer to crawl under the car than it does to change it.
    RealOEM.com list refers to it as a "back up light switch"
    Mar 2015
    1997 2.8 Z3
    I got under and checked the switch, it's a bit grimy, but looked fine. The connections seemed fine as well, but I wasn't able to check with a multimeter. Any other ideas as to where it connects/where to look?
    Apr 2014
    Newport News , Virginia
    1996 Z3 E36(7) M44
    My reverse lights went bad some time ago. It’s not an uncommon wear piece with our cars. I tested mine by replacing it. It is a cheap and easy fix if it’s the switch. They are less than $20
    http://www.bimmerfest.com/forums/sho...d.php?t=691691
    Mar 2015
    1997 2.8 Z3
    Well that thread is helpful, Thanks! I didn't know the connection piece could be the one that goes out. Guess it makes sense, I'll be sure to check that.
  1. Reverse light wiring??????
    By sideways e34 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-27-2009, 01:15 PM
  2. Install new fog lights on non-pre-wired 323IS
    By billhao in forum 1991 - 1999 (E36)
    Last Post: 08-30-2009, 01:31 PM
  3. WTB: reverse light swtich wiring w/ plug
    By Volf in forum BMW Parts Wanted
    Last Post: 06-25-2009, 10:05 PM
  4. did non fog light cars get wired or not
    By DSP74 in forum 1983 - 1991 (E30)
    Last Post: 06-23-2008, 08:09 PM
  5. Failed Inspection: Non Working Reverse Light
    By huff in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-15-2007, 04:27 PM
