RM European Auto Parts
Results 1 to 6 of 6
Thread: E92 both front outer CV boots leaking
    Apr 2018
    Arlington, VA
    2009 335i xdrive coupe
    Car: 2009 335i xdrive coupe with Dinan stage 3 suspension (57k miles)
    Boots on rear were replaced a year ago. Now the fronts have gone bad. You can see from photos below that boots look to be in decent shape other than the grease leaking out end, which is to say while the grease has come out, I doubt much dirt or water could have gotten in. The problem is I don't know how old the leak is, and while steering feels fine to me, would I be better off playing it safe and replacing the axles? Or should I just replace boots?
    My other question is on cost - BMW of Fairfax wants $1,230 for new boots and have budgeted 6 hours of labor. I'll go with an indy so will pay less than that, but does anyone know what should be the approx cost of replacing front axles? I've heard parts cost is higher but labor cost less. Thanks!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Are you sure that it’s CV joint grease that’s leaking? It’s all over the shaft which I don’t believe is the typical “spray pattern” for a CV leak.
    You could repack the CV joints and install new clamps.
    Have J&F Motors in Shirlington look at the car. They’ve been my go to indie shop for almost 30 years. The techs know what they’re doing.
    4064 South Four Mile Run
    Arlington VA 22206
    *(703) 671-7757‬
    That's definitely axle boot grease. It doesn't have the typical spray pattern because it's leaking out the back of the boot. The boot itself isn't split open like the old days.
    Apr 2018
    Arlington, VA
    Quote Originally Posted by White94RX View Post
    Does that mean all that needs to be done is repacking with grease and new clamps? Or are the boots bad and must be replaced? Thanks!
    Apr 2018
    Arlington, VA
    Quote Originally Posted by MarcoZandrini View Post
    Arlington VA 22206
    *(703) 671-7757‬
    Yes, pretty sure it's CV joint grease. Thanks for the comment and the recommendation. I've used J&F before. They replaced my rear boots a year ago and they still look new.
    Quote Originally Posted by moosejamal View Post
    I would replace them.
  1. E30 325ix Front Axle Inner Outer CV Boot Kits
    By Thor Hammer in forum Drivetrain & Transmission Parts
    Last Post: 06-11-2014, 03:50 PM
  2. FS: Genuine BMW E46 & X5 Front Inner CV Boots...
    By Ben Carufel in forum Drivetrain & Transmission Parts
    Last Post: 06-03-2010, 03:09 PM
  3. Front outer CV boots
    By Luko840 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-07-2009, 10:51 PM
  4. torn passenger side outer cv boot
    By tdz123 in forum 1999 - 2006 (E46)
    Last Post: 01-04-2009, 09:47 AM
  5. 03 X5, Replacing outer CV Boots, looking for instructions
    By TriX5 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-02-2008, 06:20 PM
