Results 1 to 3 of 3
Thread: E38 v8 vibration issue
    Sep 2017
    Florida USA
    2001 BMW 740il
    Hoping you guys can help. MY e38 v8 runs fine and smooth when driving. However, when I start it up it vibrates. The engine does not sound like it's missing. I'm pretty much mechanical savy and can figure most things out by diagnosis. However, Im stumped. When I put it in reverse it also vibrates. I did not check the engine mounts by taking them out. After inspecting them visually they look fine. I read where other issues can cause this problem like bad CAT or a vacuum leak. Any ideas? I will be reviewing the car more this coming weekend so I can do other checks if you have any suggestions.
    Note, the car was smoking on start up and i changed the vacuum pump house and OSV housing was well as vacuum hose running to brake booster. It occasionally smokes on start up, some times not at all. I filled up fuel yesterday and drove off and it hesitated a bit on pull of and smoked white. Not sure if that issue is related. Appreciate any insight.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by amarh6455 View Post
    Transmission or engine mounts if engine otherwise runs fine. But I would guess it's more of an engine issue, this is my thread about similar issue:
    https://www.bimmerforums.com/forum/s...mission-mounts
    In my case it was eventually the timing chain & guides causing rough running causing vibration. (I assume that you changed the CCV not the OSV)
    If you could hook up a notebook with INPA and see roughness that would help a lot.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, much more informative to use diagnostics:
    http://www.meeknet.co.uk/E38/Diagnostics.htm
    My BMW Repair YouTube Channel
  1. E38 735i V8 Steering Issues
    By WadiM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-10-2016, 09:37 PM
  2. Shaking & Vibration Issue: A/C Related
    By cascrnwrtr74 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-13-2005, 09:19 PM
  3. 2000 540i/6 shimmy/vibration issue
    By psychocandy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-12-2005, 07:25 PM
  4. Another vibration issue..
    By buddy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-23-2005, 08:57 AM
  5. Vibration issue after pick up from RMS
    By il328 in forum Forced Induction
    Last Post: 04-07-2003, 01:25 PM
