Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Results 1 to 7 of 7
Thread: Help! My seat leather is too tight. Leather Stretcher?
    Jan 2015
    Los Angeles, CA, USA
    2011 BMW 328i, ChevyVolt
    Hi Guys. About 6 months ago, I had a problem with the seat-belt warning coming on for the front passenger seat. This is when nobody is in the seat. Took it to the dealer a few times and they made adjustments but the warning always came back. Finally, the dealer said that sometimes the seat leather gets too tight and triggers the sensor, even with nothing on the seat. He asked if I ever conditioned the leather. I said no (didn't even know you were supposed to). Long story short, they replaced the entire seat leather for free. That fixed the problem… until now! The dreaded warning is back. It's probably a combination of California sun hitting the seats and the fact that I'm the only one in the car, so the leather never gets stretched. So now I'm thinking of a solution.
    What if i got some leather conditioner (which ever one makes the softest leather) and put a lot of it on the seat? Then, I could put some fairly heavy weight on the seat overnight to help stretch out the leather. What do you guys think? Am I crazy?
    Salem, MA
    03 zhp, 97 e36m3, 04 zhp
    While you can apply various softening products, they will always sit on the top painted surface of the leather and will never hydrate the leather underneath. A much better solution * would have been * regular use of leather conditioner with UV protectiants and /or using sun shade on the windshield to protect from direct UV damage.
    Jan 2015
    Okay thanks. I will use some conditioner, but the leather is only 6 months old!
    Salem, MA
    I honestly think the real root cause is somewhere else, specifically either in the receptacle itself or in the wiring to the buckle and your dealer can't troubleshoot it correctly. Seat leather has little to do with seat belt receptacle and I believe seat occupancy mat is under main foam parts of the seat, not on top.
    Jan 2015
    Quote Originally Posted by Mless5 View Post
    Thanks Mless5! I understand the receptacle but would you please clarify where the "main foam parts" of the seat are?
    Salem, MA
    By main foam piece I mean the piece you actually sit on that is covered in leather:
    https://www.turnermotorsport.com/p-1...uine-bmw-part/
    Those foam cushions in turn attach to plastic bucket of the seat itself:
    https://hermesautoparts.com/autopart...328Ci_330Ci_M3
    Atlanta, GA
    2019 Chevy Silverado
    Incorrect. The seat occupancy detector sits on top of the foam, between the foam and leather.
    BMW Level 1 Master Technician
  1. HELP......my rear seatbelt is stuck!
    By Mike88 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-27-2008, 06:25 PM
  2. help my seat is stuck in recline!!! (electric)
    By 89mk3turbo in forum 1991 - 1999 (E36)
    Last Post: 11-08-2007, 12:43 AM
  3. Help, my steering wheel is vibrating from 50-80mph
    By ADVANT123 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 08-11-2005, 10:06 AM
  4. I'm starting to think that my steering wheel is too big.
    By count_schemula in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-04-2002, 04:53 PM
  5. HELP......my rear seatbelt is stuck!
    By Mike88 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-20-2002, 02:52 AM
