Results 1 to 11 of 11
Thread: Laser Spark plugs
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    Laser Spark plugs
    Anybody ever use laser spark plugs and have anything good bad or indifferent information to share about them?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    San Jose, CA
    1997 BMW 540i 6 speed
    Never heard on 'em. Sounds like snake oil.
    BMW specifies the NGK BKR6EQUP for all E39 engines.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    I knew a dude who was running plasma plugs in his turbo Audi few years back. HE loved them and said he got a good bump of whorespower from them. Installation / tuning was not trivial though I don't think though. For the system he had, it was not like "oh just toss plasma plugs in and go!" You basically need to do a whole big project and then retune ignition programming.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Sep 2013
    Tx.
    02 bmw 540
    Quote Originally Posted by Mannyf540 View Post
    Wow! Interesting.
    Quote Originally Posted by edjack View Post
    My bad I should have been more specific. NGK Laser Platinum is what I ended up getting and that's what I meant when I said laser...
    Thank you guys!
    Nov 2016
    Santa Cruz, CA
    2000 540i Touring
    Sounds like you got the right ones. BKR6EQUP say Laser Platinum on the box. BKR6EK are supposedly okay but you have to change them more often.
    @geargrinder, what kind of Audi turbo engine was the change to plasma plugs done on, and did they help?
    Los Gatos CA
    1987 325is, e34, Z3, e39
    Quote Originally Posted by 300kplus View Post
    Wow! Interesting.
    Wow! That's a lot of oil from that snake!
    The core laminations are shaped exactly like those from inexpensive Chinese coils.
    https://www.aliexpress.com/item/Free...020554463.html
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    You’re not going to gain anything from a spark plug change. Just put the stock ones in it.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The only "gain" that you get from moving to modern technology as found in NGK Iridium IX plugs is a smoother idle, a better tip in acceleration, and a little better fuel economy at steady RPM when compared to a multi prong plugs. Nope no HP gains and if your butt dyno is weak you will never notice the improvement.
    These plugs provide a lower voltage requirement to bridge the spark gap allowing a longer burn time (Mil secs) thereby giving the above results. Life span is the same as multi prong plugs. The multi prong plugs were a fad in the late 90's until precious metal plugs came along and stole the title of the latest and greatest technology in plugs.
    Historical note: Champion Spark plugs Pioneered this technology with their H.O.T. plugs in the late 80's leveraging fine wire center electrodes and side straps (ground strap) that were hollow and had a copper core providing a higher temp at idle (no carbon fouling for small and big blocks w/Carbs and a lower wide open temp removing the risk of detonation issues with lower octane gasoline. Worked wonders on big block Chrysler and turbo applications by providing .2 secs in the Qtr mile and 1 minute on road racing tracks with out mods to the engine. The technology was an offshoot from their involvement in F1 racing during that time. Ferrari, McLearen, Mercedes and yep even Lambo efforts. I spent many a weekend proving this with race teams and with product XX bigots. Won over a few Ricer teams as well....
    Buy the NGK, gap them at .032", replace your plug boot if so equipped and enjoy. Most everything else is "bench racing" so unless your ready to jump to race car extremes save your $$$.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The Multiple Spark Discharge (MSD) has been around since the '80s. They provide tremendous results in race engines, modified units, etc. Cars with big cams that run real rich at idle to 2500 RPM MSD type systems provide/allows full cyl fuel burns and better drive-ability. Porsche has used that technology 1975-87 as an OE application for the above reasons. With the advent of coil on plugs, fuel injection with O2 feedback systems, it does not provide as much return on investment. Never seen a dyno pull comparison on an BMW application with any real time benefits so until then I would say, spend your $$ else where.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  1. Spark Plugs - NGK Laser Platinum?
    By JLiusifer in forum 1999 - 2006 (E46)
    Last Post: 06-26-2013, 09:43 AM
  2. Laser spark plugs
    By Max Lumens in forum 8 Series (E31)
    Last Post: 07-14-2011, 10:05 AM
  3. E36 NGK laser platinum spark plugs (6)
    By OppLock1 in forum Engines, Performance Parts & Software
    Last Post: 08-17-2010, 02:21 AM
  4. Laser Platinum Spark Plug
    By wil801 in forum 1999 - 2006 (E46)
    Last Post: 06-14-2005, 03:22 PM
