Results 1 to 3 of 3
Thread: LSD 3.91 differential is hard to turn by hand?
    South Jersey
    84 318i
    I pulled a differential from a junkyard and noticed it's kinda of hard to turn by hand when compared to other differentials I have. It is a 3.91 LSD small case diff. I changed the fluid out already. Could this be caused by the bearings on the diff or would it be the ring and pinion?
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    I think it might be toast! With new fluid in it, turn in by hand, both ways for a while and see if it loosens up. Any one of the bearings could cause a bind on a LSD. But I don't have high hopes for it.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    Apr 2015
    Toronto
    e30s
    I would drain the diff remove the back cover and inspect.See what could be making it bind. your other option is to disassemble and rebuild the diff. It's not hard to do. You will just need to get "lash" specs on the bearings.
  1. Hard to turn it on but key is not spinning
    By Daved in forum 1991 - 1999 (E36)
    Last Post: 07-15-2014, 01:35 PM
  2. My outside door lock is hard to turn the key?
    By zizou10 in forum 1991 - 1999 (E36)
    Last Post: 09-06-2006, 06:08 PM
  3. Ignition key is hard to turn
    By zrusny in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-21-2005, 12:25 PM
  4. The new 3.91 differential is great!
    By LEVOC///MPower in forum 1991 - 1999 (E36)
    Last Post: 10-09-2001, 09:45 PM
  5. I know this is hard to look at
    By danbean123 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-04-2001, 09:37 PM
