Results 1 to 25 of 35
Thread: Street Tire Choices - HOT
    Feb 2018
    Indio, Ca
    1999 BMW M3 Convertible
    I'm looking for some DD street tire recommendations. I live in the Palm Springs area where it seldom rains and can reach 120 degrees in the coming few months.
    Having recently spent thousands bringing my 1999 back to life, I'm looking for somewhat of a value tire rather than popping $650 on some Michelin PSS's. But I do want to enjoy my new car.
    Sent from my SM-N950U using Tapatalk
    Aug 2013
    1999 BMW M3 Coupe
    $650 is pretty much par for the course. Get the Michelin PSS or 4S. You aren't gonna save more than $50-100 max by cheaping out since the mid-range tires are nearly as expensive, and those are great summer tires which would be fantastic where you are. As for temperature, it doesn't really matter. You aren't tracking it so you won't be getting it hot enough to melt the tread just from street driving, even if it's 120F.
    Florida and ATL
    1999 M3 and 1990 Jetta G
    I like the Bridgestone Potenza S-04
    https://www.discounttire.com/buy-tir...sition/p/36228
    I'd also look into these Continentals...
    https://www.tirerack.com/tires/tires...e&autoModClar=
    I wouldn't cheap out too much on tires... you get what you pay for in performance/longevity in a way. And your car will be far more enjoyable on a good tire than some cheap one with bad performance. On a car with sharp reflexes like an M3, you really feel the difference.
    Feb 2018
    Indio, Ca
    Square or Staggered
    Can you educate me as to the pros and cons of each approach? Obviously if square, you can rotate which should help longevity...also obvious is the fact the car wasn't designed that way.
    Nov 2002
    Westchester, NY
    its confusing. on my 95 ltw with oem wheels we went from staggered tires to squared. on my 98 3/4/5 we put 17 inch bbs wheels on with staggered tires.
    id be lying if i said i understood why - i never go to the track, as you can tell
    Aug 2013
    1999 BMW M3 Coupe
    Quote Originally Posted by jprottas View Post
    Square or Staggered
    Easy, if you have the OEM staggered wheels (17x7.5 front, 17x8.5 rear), get the 225/45 and 245/40 staggered tires. If you have a square set of wheels that are 17x8.5 or 17x9, go for a square 245/40 setup.
    For street use there's not a big difference. Gas mileage will actually be a bit better with staggered because of the skinnier tires up front to push around. The main benefit of going square is to even out the grip front/rear to make the car balanced and less prone to understeer. Yes you can also rotate tires front to rear, but unless you run excessive camber/toe that shouldn't matter too much on the street. Personally, I have a staggered set of all seasons on my OEM wheels, and then a square set of 17x9's with summer/track tires on them for the 5 months or so of the year when it's consistently above 50F here.
    Dec 2016
    North New Jersey
    1989 325is, 1995 M3
    There's a famous saying that goes something like:
    "Be mindful of what comes between you and the Earth; always buy good shoes, good tires, and good sheets."
    Oct 2015
    Alabama
    97 BMW M3 Sedan
    i live in Alabama and i am using Hankook Ventus V12s they are great. its been a year and they drive really good.
    Current
    -1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
    Past
    -2001 BMW 325i
    -1999 BMW M3 Vert White
    -1981 VW Rabbit Pickup (Caddy) 2.0 ABA
    "I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    When running normal camber I got over 30k miles from PSSs.
    They may cost more, but they will last longer than anything even close to their levels of performance.
    From a long-term running cost perspective, they're one of the cheaper tires on the market until you start really buying cheapo garbage tires. Which would detract from the "enjoying" you mentioned.
    I know PSSs aren't THE BEST you can get, but they're close and in my experience last dramatically longer than anything even close to them.
    And $650 is a GREAT deal on them, btw.
    Valencia, CA
    Imola E36 M3 E30 Touring
    Sumitomo HTR Z III are good alternatives to pilot sports in my experience. About the only downside, they're slightly louder. Grip wise, I couldn't really tell a difference.
    https://www.tirerack.com/tires/tires...odel=HTR+Z+III
    Pilot Sports are overrated in my view. They're no where near as grippy as competition tires, and only marginally or not any grippier than other summer tires.
    Your $650 price, is that out the door (mounting and balance) or just the tires? If out the door, that's a really good price; I would buy PSS tires in that case.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by blckstrm View Post
    +2. I have a non-staggered set on both my 99 M3 and 04 M3. Likely one of the best all around street tires. Amazon is getting $710 for a set of 245/40-17.
    88M3 AW 43k miles Project FS
    Apr 2008
    Riverside, CA
    98' M3/4/5, 85' 944
    Those Sumitomo HTR Z III mentioned look like a good value to me. A street only car I would try those.
    Staggered is fine on the street my car felt fine to me till I took it to the track and was at or above the limit then they had to go.
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    These get a good rating on Tire Rack...Firestone is owned by Bridgestone I believe...
    https://www.amazon.com/dp/B01C8YUN3Y...v_ov_lig_dp_it
    Estoril/Modena '97 M3...sold for the second time.
    You only live once, and I'm running out of time...
    Florida and ATL
    Quote Originally Posted by Gene V View Post
    I came back to this thread to post these exact tires...
    They are rebadged Bridgeston R005's from overseas. Given how happy I've been with my Bridgestones, I don't think these would be a bad choice at all. And very much in the op budget. That said PSS for $650 isn't bad at all.
    https://www.m3post.com/forums/showthread.php?t=1280922
    Aug 2013
    1999 BMW M3 Coupe
    Quote Originally Posted by earthwormjim View Post
    They're some of the better 300TW performance summer tires you can buy, and generally not too expensive. Sure, they don't compare to the stickier more track-oriented 200TW tires like the Hankook RS4's that I have (or Dunlop star specs, RE71R's, etc...), but they will also give a smoother and quieter ride, last way longer, and don't degrade in cold temperatures. I strongly discourage anyone from putting 200TW or lower tires on a car which is only driven on the street, unless money is no object.
    Mar 2013
    Upstate NY
    M3
    Basically don't buy a 200tw tire just to say you have it. Only buy them if your going to use them. Basically they are for high power or track days etc. I had a set of PSS, they are great, I got just under the 30k mile life out of them. Maybe 25k but I drove extremely aggresive (tail of dragon etc). Would buy them again. Also will add that they are simply the best rain summer tire too, never had issues until past the wear bars. Anything below 20 degrees rendered them useless too.
    Virginia Beach
    e36 M3 Supercharged
    A set of PSS is well worth the $650. They're very grippy for street tires, and they last quite a while. Best overall tire I've ever owned.
    Jul 2002
    Southern California
    240SX, RRC,M3
    Quote Originally Posted by TostitoBandito View Post
    This is important on Southern California roads.
    I like Pilot Super Sports because they grip well and ride well in all conditions I've encountered in SoCal. They do thump a little harder than other tires over expansion joints but for most inputs they're well-damped- you don't have the skittishness from mid-corner bumps that some of the other ultra-high-performance summer tires have.
    The Continental ExtremeContact Sport has good ratings, especially for ride quality. I have no experience with them. You should be able to get them for around $570/set.
    America's Tire has a set of PSS in 225/245 for $634 and they have a $70 mail-in rebate when you buy four tires, so your tire price would be $564 plus tax, mounting, and balance.
    1992 Nissan 240SX Track Rat
    1998 M3/4/5 74k mile daily driver
    1990 325i Manual Sedan Project
    washington dc
    Avus Cosmos Calypso!
    You get what you pay for in tires generally - grip, wear, turn-in, braking, etc. Michelins last the longest by far. I like Michelin, BFG (sister co of Michelin), Bridgestone, Conti, Pirelli, maybe Yoko and General (sister co of Conti) and Dunlop (sister co of Goodyear). For a DD tire I like the all seasons as they last longer than summer tires with less noise. Riding on Michelins now. Read the reviews on Tirerack and look at all the specs of the tires. The Sumitomos are super narrow while the BFGs are super wide.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I think the PSS are a little over rated. I have run them on my 08 535xit and my 08M3. I think the ECS are a good value. Not far enough behind the PSS to notice, maybe a little more comfortable, just about as lightweight, and cheaper. That said, I might try P4S on the 08M3 next. But the 08 535xit may get another set of ECS.
    Jul 2011
    Austin, TX
    What about treadlife?
    I understand there are better 200 TW tires, and I understand there are cheaper 300TW tires that are almost as good, but the Michelins are the only ones I'm aware of that come with a mileage guarantee (because they do actually last).
    Aug 2013
    1999 BMW M3 Coupe
    My last set of Pilot Sport 2's (predecessor of PSS, and very similar tire) lasted between 25-30K miles on the street, and that included at least 3 track days on them as well. For street use they should be good for over 30K miles consistently, which is great for a tire which performs as well as it does.
    Jun 2005
    New England
    I did not get 30k out of PSS on either the 08M3 or 08 535xit.
    Aug 2013
    1999 BMW M3 Coupe
    I know my dad's 2008 M3 eats tires as well. I imagine an E36 with less power and weight should be a bit gentler in general, though it depends a lot on alignment as well.
    Excessive toe+camber will kill any tire. What I see often is people running more negative camber than stock, but they never bothered to reduce their toe from the stock settings which are deliberately high toe-in (in front) to make the car easier to handle in varied conditions on the street. In the rear you want toe-in, but if you lower your car and don't have adjustable lower arms you can end up with more camber than you want. Both these cases drag the tire shoulders and can cause a lot of wear.
    Jan 2015
    Los Angeles, CA, USA
    2011 BMW 328i, ChevyVolt
    Used set of Bridgestone Turanza Serenity?
  1. lsx swap street tire choices
    By birdman2447 in forum Engine Conversions
    Last Post: 04-18-2011, 12:22 PM
  2. More competitive Street Tire class choice..328 or '95M3?
    By Randy Gunn in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-25-2004, 03:54 PM
  3. Help with "hookin' up at the strip" on street tires..
    By Gimp Z3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-03-2002, 02:38 PM
  4. RE: BF Goodrich g-force T/A R1 as street tires anyone??
    By ELIBEEMER in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-05-2001, 04:44 PM
  5. what are the stickiest street tires available?
    By m3fanatic97 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2001, 02:59 PM
