BAVToys
Results 1 to 6 of 6
Thread: Unable to manually aim oem retrofitted xenons via adjustment knob...?
    Oct 2012
    Charlotte, NC
    2003 540it
    Hey everyone!
    I recently retrofitted some oem xenons from a 330i into my 325i E46.
    On the passenger side, the vertical aiming knob allows the light to go up and down.
    The driver side, no matter how much I turn the knob, nothing happens to the light. Is the gear inside broken? Is there any way to work around this issue?? The lights are currently aimed a little too low.
    Thank you in advance for everyone's help! The lights look great and really update the look of the front, I want them to be more functional too though!
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    The adjustment screw may be past its limit and isn't catching the adjusting arm. Taking it apart will paint a better picture, but I doubt that the adjuster is broken. e46 did not suffer from traditional e39 headlight issues since the design is different. Have you tried using a phillips screwdriver instead of a hex wrench to adjust?
    Oct 2012
    Charlotte, NC
    2003 540it
    Quote Originally Posted by Mless5 View Post
    Ohhh, i didn't realize to turn it with a screwdriver. I was just turning the knob which might have been disconnected from the whole mechanism. Will try with screw driver and report back!
    Peoria, AZ
    Be careful not to strip it since it' all plastic in there. Grab your meatiest phillips head driver for this and turn slow while assisting the adjustment wheel with your other hand.
    6 mm allen works much better
    Oct 2012
    Charlotte, NC
    2003 540it
    Oh wait that's true. There's no phillips head screw in there...just an allen key. But it seems like the knob is already turning the allen key as a whole...
    Still doesn't really work =X
  1. Going to by OEM Bosch Xenon Headlight for my 2000 E46
    By shoman24v in forum 1999 - 2006 (E46)
    Last Post: 03-18-2006, 07:02 PM
  2. Worthwhile to retrofit xenon headlights to my e39?
    By wludavid in forum 1988 - 1996 (E34)
    Last Post: 08-01-2005, 06:02 PM
  3. Possible to convert non ae/xenon equipped car to full oem ae/xenon? e39..
    By The Fifth Element in forum 1996 - 2003 (E39)
    Last Post: 12-13-2004, 01:19 PM
  4. complete OEM e46 Xenon retrofit
    By Charlie587 in forum BMW Parts For Sale
    Last Post: 01-09-2004, 09:31 PM
  5. Another OEM Bi-Xenon HID Projector retrofit
    By magnetic1 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-14-2003, 12:16 PM
