Anyone know if the wiring harness inside the M3 side mirror is the same as the non-M ones or if anyone sells the harness for these?
BMW only has the mirror housing as a complete unit.
Motor and heated glass spades are all the same, so the harnass must be identical.
1998 BMW M3 3.2 Cabrio Alpinweiί III on Schwarz German spec 1 of 12
SMG SRA PDC AUC OBC GSM HK UURS IHKA FGR MFL
IG: https://www.instagram.com/iflok/
There are at least two different spade types for the heated glass, one big/small and one small/small ground/power. I don't know if this is an M vs non-M difference or just a rolling production change. All the motors I have seen have been identical with the same spades.
Looks like I'm either going to have to pull some junkyard ones or just make new harnesses.
