Results 1 to 25 of 34
Thread: Reinforced Rear Shock Mounts?
    Roswell, GA 30075
    2003 540i Sport - 6 Spd.
    Anyone know if there are reinforced rear shock mounts out there for the e39 540/M5?
    --Peter
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Don’t need it so they don’t exist. Our cars aren’t pieces of crap.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I've never seen one. You shouldn't need it. Buy Genuine BMW replacements and have your shop do the installation.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The question that needs to be asked is, Why are you asking? General Knowledge or coming from the 3 series world?
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Roswell, GA 30075
    Thanks, guys. I'm asking due to the fact that I've now had TWO right rear shock mounts fail within a couple thousand miles. I had my indie install new Eibach ProKits with Koni Yellows, tasking them to also provide all the remaining necessary components, including the shock mounts. In that thread, we've all basically concluded that the install was probably done incorrectly (i.e. missing parts, parts in incorrect order/direction in the assembly, etc.). In both cases, the mounts were Lemforders. The springs and shocks are not the issue -- not broken, leaking, etc.
    My indie is going to use Vaico mounts this time around. They're OEM quality, they tell me. I'm bringing the still-assembled original rear shock/spring assemblies that were pulled out several years ago from my car (original to the car from the factory) so that they have something to reference.
    I'm going to the shop to get this fixed tomorrow and will report back.
    --Peter
    '03 540i-6
    153k mi; bought April ‘07 w/38k mi
    Silv/Blk, CWP, UUC SSK w/DSSR, M5 diff, JBR LW FW, SPEC Stage 2 clutch, Zionsville w/2-stage fan, coolant hoses, M60 intake manifold, motor-out overhaul (powder-coated VCs, TCGs, valley pan, coolant mani, head gaskets, heads refurb, all other gaskets, seals), Beisan vanos, PS pump & hoses, AC comp, fuel pump & filter, washer hoses, 88-degree thermo, DUDMD tune, Vibrant Racing muffler, Zeck CDV, Brembo solid-disc rotors w/ Textron pads & UUC SS brake lines, Dinan springs w/Koni Yellow shocks/struts, M5 front & rear sway bars, H&R 10mm spacers & studs front & rear, Pilot Sport A/S 3s, headlight adj repair, polished headlight lenses, 6k Umnitza Xenon & AE bulbs, new OEM M-Sport bumpers, gauge rings, permanent seat-twist repair to front seats, ZHP shift knob, M5 headliner kit (reinforced A-pillar clips), Schmiedmann pedals, MID & cluster pixel repair, Bavsound Stage 1 speaker upgrade & dedicated amp w/DSP subwoofers, retrofitted cupholder
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    No, Vaico is not OEM quality. They are eBay quality.
    Witness the fact that FCP Euro sells exactly one Vaico part for our E39s: the fuel door hinge.
    https://www.fcpeuro.com/BMW-parts/53...keywords=vaico
    Nate J.
    Roswell, GA 30075
    Understood. However, on FCP Euro, if you search for a rear shock mount for the M5, they only offer the Vaico. My car's an '03 MTech II -- equivalent in most ways, suspension-wise, with the M5. Different part number.
    So a question about that: what's the difference between the 540 (part number 33521094091)and M5 (part number 33522229854) rear shock mount? My indie ordered the Vaico, given it's the M5-spec version.
    Should I simply source the mounts from my local BMW dealer? They're always price-competitive, and I can get the parts faster than via FCP Euro, etc.
    --P
    '03 540i-6
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    The M5 mount looks to have an extra or integral upper spring pad, for whatever reason. I'd still recommend against Vaico parts, IMO.
    Nate J.
    Roswell, GA 30075
    Quote Originally Posted by computiNATEor View Post
    Just spoke with Turner Motorsports, and they confirmed that this is actually the same part. They also recommended the BMW part -- no surprise, since that's the direction I'd go, too. My challenge is that I need to get the car back on the road. It's a minimum of three business days until Turner would receive the part to ship to me. We were going to do the repair tomorrow.
    '03 540i-6
    Lincoln Park, NJ
    2018 M3 6MT, 2001 740iL
    I had both rear shock mounts die in my 03 m-techII within 12k miles after installing Bilstein B14s. Reason mine failed, the indy shop that installed did not include one of the required washers. ( I also hit some debris in the road that was bad enough to bend two rims on one side ) But both mounts failed. So I also went looking for stronger than stock options. Only foudn things that were meant to mate up to specific damper/coil over packages, and not an OEM type option. Ive only got 10K on them since I replaced them ( and the missing washer ) and so far so good.
    Missing part: https://www.fcpeuro.com/products/bmw...ar-33521092986
    http://www.bimmerforums.com/forum/sh...ad.php?2302291 This was my thread looking for stronger mounts. GC options were recommended then.
    Roswell, GA 30075
    Quote Originally Posted by agentrnge View Post
    Well, my hunch is that my indie forgot the support cup that goes underneath the mount and upper spring pad (https://www.ecstuning.com/b-genuine-...h/33521090282/).
    I'm struggling with what to do -- my mechanic can't warranty his labor if a part that failed is one that I provided. He can only source the Vaico rear shock mounts at the moment. I don't want to have any more issues with rear shock mounts after this, and I ALWAYS put in the best parts I can find and/or afford. Vaicos don't meet that sniff test. Still, it's on the mechanic if they didn't do the install correctly, and that caused parts to fail, so I'll likely order the Lemforders.
    --P
    '03 540i-6
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I've said it before, and I'll keep saying it: the flat-rate system does not promote holistic, careful repairs. :/
    Nate J.
    Roswell, GA 30075
    True dat. I've only had one mechanic who was consistently meticulous and whose work was always right, and that was back in the late 80s and early 90s. He took care of my 1980 Saab 900 EMS, and then my 1986 Audi 5000CS Turbo five-speed (super-rare car to find!). But he was a car nut through-and-through, also pursuing a successful rally-car career.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by killian665 View Post
    LOL.
    WTF. Who would have guessed Vaico would bother making cheap E39 fuel door hinges.
    Quote Originally Posted by peter540 View Post
    FYI Peter, be aware there is no "Turner Motorsports" anymore. Well there is for me, but not for you... The 'real' TM, at the old HQ in Amesbury MA, is now just race team + a local Indy shop. The TM selling parts on the innerwebz is essentially a different color brand face to ECS, who bought them couple years back. So really its "until ECS would receive the part to ship to me..." Kind of bummer because around here we used to be able to run over and pickup orders and look at parts in person, but now all the mailorder stuff and Turner branded parts sales moved way to some massive call / fulfillment center in the cloud.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Roswell, GA 30075
    That IS a bummer. Didn't know about the ECS deal...
    '03 540i-6
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Hmmm, I’m flat rate, I do a great job placing a safe, well repaired vehicle back in its owners hands. Have not had any comebacks, and that record goes back years and years, and still going strong. Not every shop is stocked with idiots that don’t care about their work....
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by BimmrMeUpSnotty View Post
    I know, but quite a lot of shops are, unfortunately. Thank you for your hard work.
    Nate J.
    Dec 2013
    Chicagoland area
    EXOTICS
    A rare breed, indeed. PS...keep up the great work!
    Mechanics like you seem to be the exception rather than the rule!
    Mar 2010
    Yeah, I'm not sure rate-system 100% correlates with work quality, the primary factor is integrity and character.
    However... I do know solid pro-techs who have told me yeah when they work under a fixed-rate pay-system, they are kinda incented to 'not do any extra' and probably even 'good guys' get sub-consciously incentivized to cut corners here and there, because cranking out jobs puts more money in their pocket, and seldom does anybody give 2 poops about them doing the 'extra good job' when they do...
    2003 M3CicM6 TiAg
    Former:
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Especially when it's a lease return. It's why I may never buy a new BMW.
    Nate J.
    Mar 2010
    Right. There's no 'actual customer', its just going back into the system and off to auction... Very different than "Mr. Whacknozzle is coming in to get it today and I'll see him when he does and he'll thank me for doing the job..."
    2003 M3CicM6 TiAg
    Former:
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Pete,
    I would only use Lemfoerder or Sachs strut / shock mounts.
    There is also some mounts from Ground Control:
    https://groundcontrolstore.com/colle...unt-heavy-duty
    Roswell, GA 30075
    We installed Lemforders today. Guess what we found?
    - No support cup (sits under the shock mount and above the bump stop -- a CRITICAL part)
    - No bump stop (they were supposed to have been installed, having first been cut shorter)
    - Wrong washer at the top of the assembly (too small to prevent the shock from pulling out with downward movement)
    The shop corrected everything for free and admitted their mistake. When they first installed my Eibach/Koni setup, they pulled out my Fortune Auto coil-overs, which didn't feature any of the OEM parts needed for the new setup. They should have known what parts to source, of course, but at least they were honest about everything.
    Lucky for them, this time I thought to bring the original rear spring/shock assemblies, which I'm glad I'd kept when I'd put in the FA coil overs. They served as a reminder/example of the proper setup, and they also provided side of the parts we needed today.
    Here's hoping this is the last I have to deal with this for a LOOOONG time.
    --P
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Glad to hear you got it sorted. Yes, those support cups and bump stops are critical.
    Nate J.
    Dec 2013
    Chicagoland area
    EXOTICS
    Pull up the OEM diagrams,
    you won't have to lug around the assemblies!
  1. polyurathane front controll bushings rear shocks mounts tranny reinforcers
    By restricted in forum Suspensions, Springs & Shocks
    Last Post: 08-16-2007, 10:27 AM
  2. TMS Rear Shock Mount Tower Reinforcement Plates- E36 or E46
    By Garrett M in forum Suspensions, Springs & Shocks
    Last Post: 05-12-2007, 05:56 PM
  3. e46es need reinforcement plates for rear shock mounts too?
    By wifeyse46 in forum 1999 - 2006 (E46)
    Last Post: 04-12-2005, 06:29 PM
  4. WTB: E46 Convertible Rear Shock Mounts & Z3 Reinforcement Plates
    By The-Great-328ic in forum BMW Parts Wanted
    Last Post: 08-06-2004, 01:44 AM
  5. FS: M3 Rear Shock Mount w Reinforcer
    By lkstaack in forum BMW Parts For Sale
    Last Post: 03-26-2003, 02:03 AM
