Results 1 to 16 of 16
Thread: 1997 M3: Numbers Matching?
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    All,
    I've got a high mileage M3 (229,000 miles). It is an unmolested automatic 4 door...at least one previous owner was a female.
    How do I tell if the engine is original to the chassis. It runs well and burns acceptable amount of oil (for a 90 mph commute!) so wonder if it has been replaced in the 21 years of existence.
    Thanks!
    [url=https://flic.kr/p/WqfcGf]
    Oct 2003
    Seattle
    99 M3
    As I recall, there is a VIN sticker on the aft of the head.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Only the head carries a VIN sticker and those can easily fall off during any machine shop work. Any S52 in your car is “numbers matching”.
    Oct 2003
    Seattle
    99 M3
    While it is true that “any S52 is numbers matching”, a missing matching VIN sticker opens the possibility that a “400” casting head ( w/‘lighter’ springs) from a 323/328 has been installed for a repair.
    Miami, FL
    98 M3 S54 coupe
    Any plans on selling it?
    1997 Estoril/Dove M3 sedan (62k miles)
    1999 Imola/Modena M3 coupe (1 of 2) S54 swapped
    2002 Estoril/Black M3 coupe (Individual)
    2007 Mercedes-Benz E63 AMG (500hp daily)
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Thanks folks...exactly what I was looking for. Will take a look tomorrow for the sticker. I have no service history on the power plant.
    Selling: matter of fact I am - engine and trans only.
    https://tampa.craigslist.org/hil/pts...567206204.html
    My son and I are using this car as a learning tool...swapping in an LS engine and teaching him autocross - thread:
    https://www.bimmerforums.com/forum/s...or-with-LS-T56
    Thanks!
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by bluptgm3 View Post
    While it is true that “any S52 is numbers matching”, a missing matching VIN sticker opens the possibility that a “400” casting head (containing lighter w/‘lighter’ springs) from a 323/328 has been installed for a repair.
    No it does not.
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    Unless they're rusty or damaged, i'd just rebuild the stock calipers so you know you have good parts. It's super easy, takes like 5min per caliper once its off the car.
    Put a block of wood (1x2") between the piston and floating part to catch the piston. If you don't have compress air, hold a bike pump up to the brake line and blow out the piston. (i use a bike pump). Remove boot and seal. Put in new seal and coat with brake fluid or lube. Coat piston with brake fluid or lube, put new boot on the end of the piston, stick other end of boot into the caliper groove, press piston in.
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    TXBDan: Likely a mis-post? I'm keeping the calipers...a good bleed and brakes work like new - thanks!
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by Braymond141 View Post
    No it does not.
    What?
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    The Netherlands
    DE-spec E36 328i/M3 cab
    The engine block has its number 'printed' on it. (above the left engine mount bracket for S/M5x)
    The service booklet should mention chassis number and engine number. At least there are entries for it on one of the first pages. The selling dealership should have written it down.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Thanks for the assistance all.
    I removed the engine today and found the VIN sticker on the back of the cylinder head...as was stated. I'm impressed it is original with 229,000 miles! Neat stuff...may have a new owner :-)
    [url=https://flic.kr/p/HEzbz2]
    The Netherlands
    Couldn’t those VIN stickers be ordered? An stuck on any new part?
    A number stamped in the block like the VIN is harder to tamper.
    Have you checked for the engine number above the left engine mounting bracket?
    IG:
    Sep 2002
    Vancouver
    98 M3
    For christs sakes. Yes someone could have put that sticker on there. No, someone didn't bother to do that on a 6k car so they could sell it to a collector as some numbers matching classic.
    - 98 m3, techno/anthrazit cloth, 124k and officially worthless - 89 m3, alpine/black 143k and officially old - 2000 323it, tiag/grey, 169k and officially boring
    May 2013
    Las Vegas, NV
    UFO
    Were you driving this on a trailer back from CA?
    CURRENT: LimeRockParkEdition E92 M3 - BSM/Silverstone E70 X5M - AW/Dove E36 M3
    PAST: Techno/Dove E36 M3 - Techno/Dove E36 M3 - LSB/Black E46 M3
    Feb 2008
    Herndon, VA
    99 M3
    Who would have thought that nobody went through the trouble of swapping another S52 into this 20 year old car to dupe the next owner?
  1. FS: E30 M3 with numbers matching rebuilt S14
    By pizzaflyer in forum 3 series & Z Series
    Last Post: 10-04-2010, 12:16 PM
  2. FS: 1997 M3/4 Alpine White
    By Jim//M3 in forum BMW Parts For Sale
    Last Post: 08-05-2001, 04:59 PM
  3. FS: 1997 M3 Coupe 5spd
    By Brandonb in forum BMW Parts For Sale
    Last Post: 08-01-2001, 02:51 PM
  4. FS: 1997 M3/4 Alpine white
    Last Post: 07-18-2001, 06:00 PM
  5. 1997 M3 For Sale!
    Last Post: 05-10-2001, 08:14 AM
