So whenever I start my car now, the little info window gives a ding and tells me what my range is. This is the display behind the steering wheel. It used to ding and come on whenever I was driving and down around 30 miles. Now every time I start the car. Ding! "Range 445 miles".....Ding! "Range 287 Miles" etc...
Any ideas on how to stop this?
See your Owners manual. It is in the glove box or available online.
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
Not sure what your helpful tip is pointing to, maybe I'm just dumb
What I am talking about is the warning signal you typically get when your down to about 30 miles left on a tank. You get a Ding! and a range pops up. This is usually 10-20 miles after the yellow low fuel LED has activated. Now the range message flashes briefly and dings whenever the car starts and flashes momentarily whenever I turn off the car. As I understand it the ding is typically activated when the OBC detects very low fuel. I have never received a fuel Ding! with 400 miles left in the tank.
I'm not curious how to change the Check Control Display to read something else or to add or subtract info messages. It seems the computer for some reason thinks a fuel warning Ding! is required at startup. Battery is fully charged, nothing was changed in regards to OBC, MIDI, etc. It just started one day. Pretty familiar with the tank and I don't remember a separate sensor for low fuel. Maybe there is one and it's incorporated with something else?
Addl: Noticed it also occurs if I turn the key to position 2 without starting the car. However, after doing that, the ding/msg doesn't occur again until I've cycled through restarting the car.
Hmm... maybe try unplugging your battery after the trunk light goes off? That seems super weird that it is doing that.
2003 BMW 540i M-Sport in Sterling Grey | Sold 2/2020
Thanks for the suggestion. Did just that, actually let is sit overnight dc'd. Gone on about half dozen drives today and no fuel warning!
Never had this issue in 16 years.
Thanks for your helpful tip jriley.
