Results 1 to 8 of 8
Thread: Ambient temp sensor periodically shows wrong temperature.
    Apr 2018
    Norway
    X3 F25
    I have a X3 F25 2013 model where the outside temp sensor shows different wrong outside temperatures from time to time. It´s different values from time to time when it shows wrong temperature. Could be as simple as a faulty sensor, or should it then be showing a fixed minus degree temperature (with short circuit, loose cable or similar)?
    Anyone with the same kind of issues?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Most likely it’s a bad connection at the sensor. The sensor is a thermistor, a resistor that varies in resistance as the temperature varies. That is, as its temperature increases it’s resistance decreases. Check the connectors for corrosion and loose pins.
    Apr 2018
    Norway
    X3 F25
    Thanks a lot, checking!
    Apr 2018
    Norway
    X3 F25
    BMW service installed new sensor and new connector, but I still have the same problem.. Any tips?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Has the car ever suffered damage to the front end? Are you faving an other electrical or electronic problems?
    Apr 2018
    Norway
    X3 F25
    No damage on the car, and no other electronic problems..
    Btw, a month ago the car thought both left side doors where open so it was impossible to drive. But that issue never came back..
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Hmmmm, how old is the battery? Are you having any other electrical issues. Modern cars are rolling computers. Whacky voltages cause whacky issues.
    I’m betting there’s a bad connection somewhere between the sensor connector and the electronix. Also, how hard is it to inspect the repair work? We all make mistakes. Many the tech didn’t do a perfect job.
    Apr 2018
    Norway
    X3 F25
    Battery is 5 years. Where is the other end of the temp sensor wiring connected?
  1. WANT: stock ambient temp sensor
    By SupaBimma in forum BMW Parts Wanted
    Last Post: 09-17-2004, 08:08 PM
  2. WTB: ambient temp sensor connector
    By hc1001 in forum BMW Parts Wanted
    Last Post: 08-18-2004, 01:22 AM
  3. WTB: Ambient temp sensor plug or socket
    By poynter in forum BMW Parts Wanted
    Last Post: 06-08-2004, 10:55 AM
  4. 1990 735i ambient temp sensor
    By TurkishSupra in forum 1995 - 2001 (E38)
    Last Post: 04-16-2004, 07:10 PM
  5. What does the ambient temp sensor look like?
    By blondie in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-24-2003, 01:23 PM
