Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: I read sooo many posts.... but what’s the real deal?
  1. #26
    Apr 2008
    Hudson Valley, New York
    Too many to list.
    It’s at the shop now, getting some all around love, but I’m going to do the exhaust in little bits and pieces. I want to try a little of this and a little of that without going all in on stuff and not liking it.
    As far as the tips are concerned, I think the placement of them is key, and nothing drives me crazier than having tips hanging out the back like a diving board. I’m not into them for a huge amount, and if I don’t like them I can easily swap them.
  2. #27
    Rigel 7
    M3, 850i, E30T, E55T
    Quote Originally Posted by nah2323 View Post
    So Adam, you left everything including the resonator stock, and just straight piped after that?
    Yes, just the mufflers were replaced with straight pipes to dual exit tips on each side.
    Quote Originally Posted by dragon850 View Post
    The best I found so far is this: Eliminate center resonator with X pipe, sizable improvement in sound. If that is not enough eliminate both mufflers with Y pipes and tips.
    I still need to hear this resonator/straight pipe combo sound...any sound clips available?
  3. #28
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by adamnur View Post
    I decided to leave the remus mufflers on my car with an x pipe. The x pipe and muffler delete cars are all late Jons cars, when I get up to the ranch next time I will take a video.
    Sent from my SM-G892U using Tapatalk
  4. #29
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by whiteghost1 View Post
    Will that 2x m20’s tied together myth ever die?
    If you’ve ever worked on an m20 & an m70 you’ll know that they have absolutely nothing in common except a few generic parts.
    People still haven’t figured it out....
    The M70 was the very distant evolution of the "hackjob" V12 intended for the E23, but that's about it.
  5. #30
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    It’s not a myth lol. They have the exact same stroke, compression ratio, bore, they’re both SOHC. The only real difference is it’s an aluminum block. It’s two 2.5L M20s joined at the hip with some updates and a timing chain instead of a belt.
  6. #31
    West Coast
    two 3's one 5 three 7's
    I apologize to the OP in advance to pollute your thread, I just have to state the facts as I know them to quell this perpetual 2x M20's joined together statement once and for all.
    Quote Originally Posted by killian665 View Post
    Wrong.
    There's quite a bit more to it than that. I guess a lot of engines must be the same with such arbitrary guidelines. Might as well call an M62 two M42's joined at the hip together according to your intellegent logic.
    Is it now......keep reading.
    Lets look at the differences that really matter and see if what you are saying holds water. Those that ACTUALLY KNOW these engines and don't regurgitate info off of the interwebz + research the facts, can conclude if they are the same or different:
    M20 vs M70
    M20 bore (mm) = 80 or 84
    M70 bore (mm) = 84
    M20 block = cast iron
    M70 block = alusil
    M20 exh port = nicely radiused w/ceiling
    M70 exh port = flat floor
    M20 exh port profile = round
    M70 exh port profile = square
    M20 intake port profile = rectangular
    M70 intake port profile = round
    M20 stroke (mm) = 71 or 75 or 76 or 81
    M70 stroke (mm) = 75
    M20 compression = 8.8:1 or 9.7:1 or 8.5:1 or 9.0:1 or 10.2:1 or 11.0:1
    M70 compression = 8.8:1
    M20 pistons = flat top or profiled
    M70 pistons = flat top
    M20 rods (mm) = 130 or 135
    M70 rods (mm) = 135
    M20 cam drive = belt - manually tensioned w/pulley
    M70 cam drive = chain - hydraulically tensioned w/guides
    M20 cam clearance = manually adjusted
    M70 cam clearance = hydraulic lifters
    M20 cam gear drive = fixed timing
    M70 cam gear drive = manually adjustable timing
    M20 cam duration = 250 or 256/258 - depending who you ask for the latter
    M70 cam duration = 248
    M20 intake (mm) = 40 or 42
    M70 intake (mm) = 40
    M20 intake (mm) = 34 or 36
    M70 intake (mm) = 36
    M20 intake metering = air flow meter
    M70 intake metering = mass air flow
    M20 PCV system = fixed tube w/orfice
    M70 PCV system = volume control valves
    M20 engine mounts = solid rubber
    M70 engine mounts = hydraulic
    M20 throttle body = cable actuated
    M70 throttle body = drive by wire
    Well the M20 & M70 does share the same fuel injectors, distributor cap/rotor, coolant sensor, and air filter.......you know, the parts that are crucial to the engineered design, and define an engine (you forgot those ones BTW). Let's not forget that they both safely run on 87 octane. Wow, look at all of the similarities!
  7. #32
    Mar 2012
    Auckland, New Zealand
    1991 BMW 850i
    Very interesting info, Whiteghost. Pity Killian’s just a troll so your facts won’t matter.
    Back to the OP, I removed the cats and fitted a X pipe just before the stock resonator with some fairly cheap magnaflow back boxes and it looks and sounds fantastic. Will record a video.
    In my experience, removing the stock resonator just creates volume and drone.
  8. #33
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    You posted specifications from both the “i” and eta M20s to make the M70 seem less similar. Don’t worry I’d be mad too if I had to play games with my google search to convince someone my V12 wasn’t a turd lol.
    All the “differences” you listed are negligible. The motor mounts are different, really lol. The internal dimensions and overall design of the engine are the same as the 2.5 liter engine. Nobody means it’s quite literally 2 M20s welded together, yes there are minor differences. But the architecture is an M20. I don’t see how anyone could argue that unless they’re like you and want to quote how the throttle opens as an architectural difference.
    By that logic M6x engines aren’t related because ones got vanos and different cams. Motor mounts are different in the X5s than they are in an E39. Must mean it’s a totally different engine I guess.
  9. #34
    Jul 2016
    Chicago, Illinois
    are slow
    All M6x heads and blocks bolt onto one another, don't even try with that.
  10. #35
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by jeffbebe View Post
    Trust me there is 0 drone if you replace stock resonator with an x pipe.
    Wrong.
    M20 vs M70
    M70 bore (mm) = 84
    M70 block = alusil
    M70 rods (mm) = 135
    I think this settles it once and for all.
    I love M70 for it's durability and ability to withstand quite a bit of boost on stock internals.
    Yeah it's sluggish in stock form, I often joke that original engineers built the M70 with a thought of boosting it down the line lol
    You breathe on M70 a little bit like 10 11psi and modified corvettes get left in the dust with drivers mouth wide open in shock...
  11. #36
    Mar 2016
    Tyler, TX
    1992 E31 850i
    Indeed. My M70 "turd" is at 10.5psi and produces 500hp as dyno verified at the wheels -- so call it just a bit shy of 600hp at the crank. Torque numbers are even higher. I could go well beyond that with minor work, like head studs, but that particular build has already well surpassed the "fun enough, what's the point" zone.
    Cheers, John
  12. #37
    San Jose CA
    1991 850i S70 6 speed
    Killian no no no my friend. Go on MWrench whitepages and read ... read a lot
  13. #38
    Apr 2008
    Too many to list.
    That’s just plain nuts! I can’t believe how raw nasty that sounds..
  14. #39
    West Coast
    OK, this is the last response OP I promise. Anything more after this will loose it's (factual & entertainment) value and is a waste of my time.
    Some people's children.....
    Yes I did post the specs of the “e” and “I” variants because an m20 is an m20, remember an m70 is 2x m20’s joined together, right? We all appreciate that you confirmed that they are not similar. We really do. Unlike you I've actually worked on and know both engines intricatly, and can back up my statements with data.
    So a cylinder head design that is COMPLETELY DIFFERENT from top to bottom is neglegible.
    As is the entire cam drive system that is COMPLETELY DIFFERENT is neglegible.
    As is the intake tract that is COMPLETELY DIFFERENT is neglegible.
    All the other (relevant) specs I posted presumably are neglegible.
    The only info I was hesitant to include was the comparison of the base metals of the primary components, which I'm not going to bother with as I don't think many would care TBH. Unlike you, I actually want to disseminate information which hopefully someone can appreciate, as I would in return. My only repsonse is - please tell us that you're only a hack mechanic who spreads fallicies and aggravation, and are not influential in the automotive industry.
    I’m glad you made a point (or two later on) about the motor mounts, I threw that one in there with a laugh whilst, because I suspected there'd be a chance you’d pick up on it.
    Brilliant.
    You know, I know, and everyone reading knows that you don’t have a leg to stand on so you're setting the bar, gutter low, on that one. However in case you didn't realize I also threw in other minutiae such as the cap/rotor and air filter which you forgot to focus our attention on. Oh well, can’t say I didn’t try. Perhaps you can provide actual details rather than the irrelevent/incorrect same bore, stroke, compression, or motor mounts argument.
    Well duh, the M6x are from the same engine family so of course they are the same. And to put it in your intellectual language, they have the same "architecture" and is an evolution from M60 to M62 to M62tu. Since you insist on being educated publicy, the tu (AKA vanos) in M62tu stands for technical update from BMW. And as XAlt so kindly pointed out the parts ARE interchangeable between all M6x (may run into valve->piston clearance issues with certain combos though) - unlike the M20/M70. And no he didn't get that from playing games with his google search, he actually knows what he's talking about.
  1. OT, but what the hell...
    By felonious monk in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-24-2007, 03:26 AM
  2. Replies: 5
    Last Post: 05-30-2006, 12:11 PM
  3. Prolly a repost but what the hell..
    By CJ in forum Off-Topic
    Last Post: 07-22-2003, 10:40 PM
  4. Dunno if this is a repost, but what the hell
    By Pepe240sx in forum Off-Topic
    Last Post: 02-25-2003, 09:21 PM
  5. Fuel Injector Cleaner - What The Real Deal?
    By BMW325i in forum 1991 - 1999 (E36)
    Last Post: 01-29-2003, 02:29 AM
