Results 1 to 13 of 13
Thread: Blend door motor(s), HVAC controller...?? Air circulation not right
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    Hi All,
    I am currently not having air flow through the "defroster" (top of the dash) nor are the passenger controls working; air only comes out at footwells regardless of setting on HVAC controller.
    I read a few posts about the wrong temperature air coming out of the specific vents they're supposed to and learned a few things. I have been able to confirm that the actuator motors on both Driver and Passenger are working as they should. The damper doors both open and the 'AC vs fresh air' vent door work as well. I put in new filters at the damper doors.
    It would seem to me that either my blend door motor on the passenger side is dead; or the HVAC controller is shot. Either could be the culprit, just not sure and am hoping to narrow it down before either buying another HVAC controller or taking out the dash to get the blend door motor(s).
    When I select "Max AC", the button does not light up and nor does it go into Max AC mode. I can manually set the fan speed I want, and either fresh vs. AC air, but, when I select either dash or feet on the passenger side, the buttons do light up but the air ONLY comes out at the feet.
    Driver's side works as it should, however, when I select the defrost button, the fans kick on to full speed, but, no air comes out the top of the dashboard at the base of the windshield.
    Any ideas?
    Thank you,
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Kansas City, MO
    2x01 750, 01 740
    The "Max A/C" not lighting up may mean it needs some coding, but is separate from your other issue, which sounds like one of the two small 3-pin cables is unplugged from the back of the controller.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
    Oct 2007
    Bolton, MA
    Quote Originally Posted by psjr View Post
    Thanks psjr. Just to be clear, the "controller" is the what I'm calling the "hvac controller" with all the fan speed settings, temp, direction, AC, etc. just below my radio?
    Thanks,
    Jay
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by jpilk99 View Post
    ...Just to be clear, the "controller" is the what I'm calling the "hvac controller" with all the fan speed settings, temp, direction, AC, etc. just below my radio?
    Thanks,
    Jay
    Just an FYI...that component's name is your IHKA control module.
    Oct 2007
    Bolton, MA
    I wonder, if by me disconnecting the IHKA control module has caused this problem ...sounds like I may hav to go get coded?
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    I replaced some push buttons in mine to fix some problems. I did not have to code it.
    https://www.bimmerforums.com/forum/s...0#post29618860
    Page 20 shows the photos of my control head apart and the switches I swapped.
    Oct 2007
    Bolton, MA
    Thanks!!! I'll give it a try
    Oct 2007
    Bolton, MA
    Gettin back to this thread that my control unit seems to be workin fine, (able to adjust fan speed up and down, temp settings, MAX AC etc), but, when I try and direct air to come out passenger vent, it just goes out to their feet. And when I try to use defrost, I can hear the internal air flow behind the dashboard changing ...but nothing comes out the top (defrost).
    If I pull off the dashboard ...is there a way to test the blend door motors?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    BMW software can tell you if the stepper motors/actuators are working properly.
    Oct 2007
    Bolton, MA
    Thanks Mayor. Bummin' that I don't have BMW software, nor do I know anyone - other than my mechanic who charges $100.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Not sure if you can get your hands on the blend motor or not. Looks like it's close to the passenger side cabin filter.
    M35, X664
    LH side of RH footwell
    M35 Defroster flap motor
    X664 Component connector (3-pin, black), Defroster flap motor
    Kansas City, MO
    2x01 750, 01 740
    Did you take the IHKA out and check that everything is connected?
    Oct 2007
    Bolton, MA
    I did not. Will try that.
  1. HVAC no air comes out, blower motor is defective if regulator output has voltage??
    By Quebecer77 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-10-2015, 10:19 AM
  2. 96 328is blend door problems/HVAC system
    By NoVA328is in forum 1991 - 1999 (E36)
    Last Post: 08-09-2014, 07:30 PM
  3. HVAC, air circulation stepper motors not working.
    By Sabreslight in forum 1995 - 2001 (E38)
    Last Post: 08-27-2012, 11:06 PM
  4. Blower Motor changed but still no air circulation!!!
    By Jeremyshrum in forum 1999 - 2006 (E46)
    Last Post: 01-28-2011, 02:16 PM
  5. HVAC blend door, steppers, etc etc
    By jfj707 in forum 1988 - 1996 (E34)
    Last Post: 01-09-2010, 10:50 AM
