Results 1 to 25 of 67
Thread: Spin on oil filter adapters
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    A member on another forum just contacted me and asked if I would do a group buy regarding the spin on oil filter adapters. If 5 guys step up between the various forums I will do so.securedownload.jpegComplete filter unit.jpg
    These provide for better oil filtration and a clean oil change.
    I make them to fit the old style 4" bottom bolted canisters, the 3.5" bottom bolted canisters and the 3.5"top bolted canisters. These will work with a BMW oil cooler filter head as well. To the best of my knowledge I am the only one providing them for a top bolted filter. My adapters are made to fit a filter for a 460" Ford big block
    My regular price is $150 shipped and I will do $130 shipped for a group buy, USA only .Additional postage to another country
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Need 2 more people for a group buy
    May 2018
    Northwest Ohio
    1988 E24, 1997 E38 740iL
    If anyone is on the fence about this, I have bought this kit from Bert a couple years ago, over at BigCoupe.. he is a stand up guy, and this kit works very well.. I use a nice and large Mobil 1 M1-301 filter and it works great..
    Pete
    North Carolina
    '86 M635/'10 Clubman
    Bert is absolutely one of our best members!
    Quote Originally Posted by Bert Poliakoff View Post
    Bert - does this work for M6/M635 as well?
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Hi Lee, Your "M" car should have a 3.5" diameter existing canister. The bolt holding the canister to the filter head should either go in from the top of the filter head or the bottom of the canister. It will work with either one of those configurations including a filter head with an oil cooler provisowhich your car should have with a bottom bolt.. Long story short, it should work. I have sold close to 100 of these and there have not been any fit/mechanical problems
    North Carolina
    Mine does bolt at the bottom. OK - will get back to you!
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    No rush, I am still waiting for several guys who "comitted" to actually step up.
    Oct 2017
    Illinois
    1979 635csi
    Bert,
    I'm interested in getting one of these. I tagged you in a message on facebook. Wasn't quite sure the best way to get ahold of you.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Maybe I will if 5 guys step up.
    The last several times I did this it was like pulling teeth getting people to put their money up. So, if 5 guys step up and put their money up front, then I will gladly do it. I will offer it on several other forums to increase the possibility of getting 5 people. Group buy price $135 shipped in the USA
    Jun 2018
    MT View, HI
    '80 733i , '76 2002
    I'm in for one. Simplify my life. Will work on the b32 in an e23, right?
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Will keep you in mind but I only have one other guy so far and 2 maybe's. Should work on an E23 as long as the canister mounts on the bottom of the filter head. Again, I will keep you advised
    Jun 2018
    MT View, HI
    '80 733i , '76 2002
    Hello Bert, I tried to PM you, but my sent box is empty. I tried twice.
    North Carolina
    Howdy Bert - what's the conversion process? I assume it's reversible?
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    It's a matter of just screwing in/on, depending on your housing, a threaded bushing into your filter head and then the adapter plate threads onto that against the filter head aligning with the existing oil ports. It will also work with an oil cooler filter head. It is 100% reversible. A total no brainer to install or remove.
    Jul 2018
    Northford, CT 06472
    1987 BMW M6
    Hi Bert, I would like to join in on the group buy in for the spin off filter. Please let me know about details. Thank You, John
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    JohnIt will be a while. Several guys have replied and then gone wonky. So when I have the real people in line I will let you know.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Quote Originally Posted by 87BMWM6 View Post
    John Check your PMs This is a go and I need you to contact me so I can tell you what info I will need
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    John need money and measurements as per the email I sent you by monday as the order is going in then,
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Yes it will work I have sent you a PM request for the info I need from you to proceed, I am shutting this off Monday as I have more than enough to move forward so you should get to me over the weekend.
    Jun 2018
    MT View, HI
    '80 733i , '76 2002
    My adaptor arrived . What a great looking part.
    Talk about simplifing my life. From now on it's a PH8 spin on, instead of dripping internal filter.
    Thanks Bert!
    Aug 2011
    Metairie, LA, USA
    1985 BMW 745i, & 635CSI
    Bert will these work on the m106?
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    If I am correct, the 106 is a turbo'd m30 as found on the 745. It is an M30 and uses the M30 canister oil filter assembly bolted from the bottom. The diameter of the canister is 3.5" If this is what you have, or even if it is bolted from the top, my adapter will work for you. Measure the diameter and let me know. check your Pms
    Dec 2012
    NC
    Audi R8 / BMW 635CSI / N
    Count me in on this pls.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    I have enough guys contacted me to do another run. Anyone wanting to get in let me know by end of day Monday. Look at original post for pics and pricing.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Last call
  1. FS Spin on oil filter adapters
    By Bert Poliakoff in forum 1976 - 1989 (E24)
    Last Post: 09-09-2015, 02:23 PM
  2. FS spin on oil filter adapters
    Last Post: 04-28-2014, 03:39 PM
  3. Spin on oil filter adapters
    Last Post: 12-01-2013, 02:08 PM
  4. FS Once again. Spin on oil filter adapters
    Last Post: 11-20-2013, 07:39 PM
  5. Spin on oil filter adapter head
    By M6csi in forum 1976 - 1989 (E24)
    Last Post: 02-13-2009, 01:46 PM
