Results 1 to 2 of 2
Thread: Computer compatibillity issues
    Las Cruces, NM
    BMW M6 M63 V10 6 sp
    I recently purchased a K+DCAN USB INPA software and wire connector kit. It states I have to assign COM1 to the USB serial port (COM X). My HP computer is all USB, how do I assign a USB port to a COM port and call it COM port 1?
    The instructions state to go to Device Manager, then Ports (COM & LPT). My computer does not have that option.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by jvsantosmd View Post
    Make sure you have cable plugged in to laptop (any usb port) when you attempt this.
    It is a software defined com port number, and your (Windows) computer will have the option. What windows are you on?
    See if this helps:
    Connection Troubleshoot.pdf
    It can be any COM port number, as long as it matches what is written in the OBD.ini file found in C:\ediabas\bin folder.
    Let us know if you need help reaching Device manager.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. Onboard computer Temp Issue
    By KOLDY in forum 1991 - 1999 (E36)
    Last Post: 01-23-2007, 02:13 AM
