Results 1 to 9 of 9
Thread: No air coming out of center vents only from defroster
    Sep 2015
    Canada
    2006 550i M-Sport
    Hello everyone,
    I'm not getting any air coming out of the center dash vents or the lower feet vents from my 2006 550i. Air is blowing from only the windshield defroster and the rear passenger vent. Ive checked the a/c fuses and tried adjusting the vents in idrive. It doesn't matter if its set to heat or AC-nothing changes. Any ideas?
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Pull the codes on the IHKA module with a BMW compatible code reader.
    Sep 2015
    Canada
    2006 550i M-Sport
    Quote Originally Posted by jtbgonesailing View Post
    I tried to use INPA to check for codes but nothing was found, I haven't used this software much though so I might not be using it correctly. In INPA I select the chassis, engine and build date then select read error memory and no errors show up. How do I read a specific module?
    Jul 2017
    Oxford, MS
    2010 BMW 528xi 2001 530i
    Sounds like a vacuum leak somewhere.
    2005 RHD TJ Sport
    2010 BMW 528xi
    Sep 2015
    Canada
    2006 550i M-Sport
    Quote Originally Posted by zipman35 View Post
    2005 RHD TJ Sport
    2010 BMW 528xi
    As far as I know all the vent doors/diverters are opened and closed by stepper motors not vacuum.
    Sep 2015
    Canada
    2006 550i M-Sport
    Got the IHKA codes,
    9C5C IHKA evaporator temperature sensor
    9C60 Heat exchanger for heating system sensor,right
    9C67 Heat exchanger for heating system sensor,left
    E706 Heater A/C system LIN bus fault
    A few months ago I removed the climate controls when I installed a Bluetooth Aux input im wondering if these could be related to that.
    Feb 2010
    Atlantic Beach, Fl
    Absent any codes for the condensation/mist sensor, the IHKA panel would be a good starting point to ensure the connectors are properly seated. There are 3 connectors on the rear of the IHKA panel, 26 pin, 12 pin and 2 pin connectors. Focus on the 12 pin connector, center of the 3, to ensure its connected properly. The IHKA can be reinstalled and run prior to the reinstalation of the trim to check functionality.
    Sep 2015
    Canada
    2006 550i M-Sport
    You were exactly right the 12 pin connector wasn't locked down correctly. Vents and A/C are now working great again! Thanks for your help.
    Feb 2010
    Atlantic Beach, Fl
    You are certainly welcome and happy it was an easy fix for you.... Enjoy the summer!
  1. No air coming out of front, side or floor vents
    By VoulaS in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 01-29-2012, 02:26 PM
  2. No air coming out of front, side or floor vents
    By VoulaS in forum 2011-2016 (F10)
    Last Post: 01-26-2012, 10:23 PM
  3. No air coming out of any vents
    By santogd182 in forum 2001 - 2006 M3 (E46)
    Last Post: 09-21-2011, 11:29 AM
  4. no air coming out of vents
    By sk8er94803 in forum 1991 - 1999 (E36)
    Last Post: 02-20-2011, 01:25 PM
  5. no air coming out of vents
    By gdizzle in forum 1996 - 2003 (E39)
    Last Post: 09-30-2007, 11:45 PM
