Results 1 to 4 of 4
Thread: 95 m3 master cylinder replacement
    Trussville, Alabama
    95 BMW M Techniq SCCA Ep
    Brakes on my 95 M3 absolutely suck. Have run 3 quarts of fluid through the system (note: race car, no ABS, Tilton rear bias valve) and they suck. I am considering removing the brake booster and replacing the MC with a smaller unit. Since the stock one is 25mm, what suggest you for a replacment?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Chuck Baader View Post
    Soft pedal?
    There is a pretty good thread regarding replacement of the “bomb” - brake booster (oddly NLA in NA)- as it relates to soft pedal.
    Guys are sourcing them from Europe.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    WAIT! What?
    Are you putting brake fluid in, then putting more brake fluid in, then more brake fluid in?
    If yes, then you are not having a master cylinder failure. The master cylinder can fail, and not a drop of fluid will be missing.
    If fluid is leaving the system then it leaving through a wheel cylinder/caliper or the clutch slave cylinder -- hydraulically in the same place in the respective circuits.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    If the brakes suck, you would want a larger master cylinder. Not a smaller one. More master volume=more fluid pushed=stronger braking.
  1. Clutch master cylinder replacement!@#
    By mrhmmhmm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-10-2007, 10:26 PM
  2. Replies: 11
    Last Post: 03-15-2004, 11:41 AM
  3. For Sale: Brand New OEM BMW E36 M3 Master Cylinder
    By ///M-COZMIC in forum BMW Parts For Sale
    Last Post: 03-07-2004, 11:31 PM
  4. clutch master cylinder replacement
    By imprttuner88 in forum 1983 - 1991 (E30)
    Last Post: 01-30-2004, 12:59 PM
  5. E36 M3 master cylinder...where to buy?
    By GR8 Ride in forum 1992 - 1999 M3 (E36)
    Last Post: 10-28-2002, 01:57 PM
