RM European Auto Parts
Results 1 to 4 of 4
Thread: snapped cam cap studs
    Mar 2018
    Ohio
    2001 BMW 325xi, e46, m54
    Lol..... After a month I finally got the cylinder head bolted down properly. And onto the next step... And of course I snapped 2 of the studs for the camshaft bearing caps... Lmao... I think for one, I misread the torque value. It should have been 10ft lbs, and I was using 14... I was also using my 1/2in torque wrench, so in hindsight that was probably a mistake also 😂
    .. and now I get to wait another week for more parts before moving forward, sigh...
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    This gives you time to have a beer or two!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Yes, the spec is 14 Nm (10 ft/lb)., and a 1/2 drive isn't right for that torque.
    I hope you are being extremely careful with tightening those nuts. The cam must be brought down perfectly square, each nut tightened 1/4 turn at a time, in sequence, unless you're using the official tool which holds down the cam. These cams are hollow, and will break very easily.
    Chris Powell
    BMWCCA 274412
    Mar 2018
    Ohio
    Yes I was very careful about doing it in proper sequence. I believe I had the second and 6th lobes resting on the lifters. Then I tightened each nut a little at a time. I got everything hand tight. I was very careful up until the point where I used a 1/2in torque wrench and misread the torque values lol.
    While we're on the subject, I'll be needing to get a new torque wrench and I was looking at the digital torque reader that just attached to your rachet or whatever... Already own the 1/2in, should I just get the 3/8th or the digital? Just never used the digital one and not sure of the cons
  1. S52 cam cap stud pulled out of head.
    By graphite9 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2020, 02:07 PM
  2. I just snapped a waterpump stud
    By mr rolleyes in forum 1992 - 1999 M3 (E36)
    Last Post: 04-27-2008, 12:19 AM
  3. Broken cam cap! Is line boring needed?
    By sausrigging in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-11-2007, 12:22 PM
  4. M50 Cams, trays and cam caps cheap
    By Goofynick6 in forum BMW Parts For Sale
    Last Post: 11-06-2006, 11:45 AM
  5. Project Bundling: Cams, HG, Studs, and……..
    By ///MDex in forum Forced Induction
    Last Post: 01-12-2006, 10:28 PM
