Hi; Tried SEARCH, came out empty: My car needs the throttle actuators replaced. I already bought the pair (aftermarket gears, electronics with lifetime warranty). My question: how difficult is it for a weekend mechanic? There's a video on YouTube that explains it very well, but... it doesn't give too much info on difficulty factor. Maybe the person doing it is a professional. Is this something a regular Joe can tackle? there's not really that much engine disassembly. Please advice.
The book says 6.5 hours for both. This will be for a pro with all the tools.
It's important to note that when you're done, you need to use ISTA to perform a test sequence on the new throttle motors, which I believe is what resets the adaptations.
Here are the actual factory directions, minus the pictures (sorry):
13 62 540 - Removing and installing/replacing throttle valve servomotor (S85)
Zoom/Print
Necessary preliminary tasks:
- Read out fault memory of DME control unit; if necessary, work through test schedules
- Switch off ignition
- Remove intake air manifold See: Intake Manifold > Removal and Replacement
- Release positive lead on cable duct at front and rear
- Remove cover for ion control unit on left and right
- Remove cover for ignition coils on left and right
Zoom/Print
Release bolt on cable duct (1).
Zoom/Print
Release nut on cable duct (1).
Tightening torque 12 52 3AZ .
Unlock plug in V-chamber and disconnect, lay cable duct (1) to one side.
Zoom/Print
Note:
Illustration shows and description refers to the left throttle valve servomotor. The procedure is identical for the right filter housing.
Remove pull rod (1).
Unfasten screws.
Remove throttle valve servomotor (2).
Zoom/Print
Important!
After performing work on the throttle valve system (throttle valve assembly, servomotor, Hall sensor), it is absolutely essential to carry out a throttle valve actuator system test with the BMW diagnosis system!
Function selection:
- Complete vehicle
- Drive
- Engine electronics
- Air supply
- Throttle valves
- Throttle valve actuator
Zoom/Print
Note:
Check stored fault messages.
Now clear the fault memory.
Chris Powell
BMWCCA 274412
It's not a really difficult job, but there is a lot of room for error. It takes experience to remove all the hoses and vent lines without breaking anything. Also make sure all the rubber connections are properly seated on the throttle bodies.
