Results 1 to 9 of 9
Thread: DIY Kony coilovers
    Yonkers, NY and Argentina
    1998 528i 5speed Sport
    DIY Kony coilovers
    looking around the internet and talking to different people, found some cool info for making your own quality coil-overs, performance wise. the info is from a DSM autox, but should relate to all cars.
    http://farnorthracing.com/autocross/konis.html
    Ground-control sell the top mounts (or ebay for the price checkers)and can find the sleeves from them, summit, jegs, or your neighborhood circle track supplier. Same for the springs, lots of suppliers and price variety.
    All in all a good week end project
    e30 325i, the mighty 4 door granma mobile....Gone
    e39 528i, 4 door sports tank
    Jun 2010
    Bay Area, California
    325iT, 540iT
    Kony 2012
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    LOL.
    Koni.
    Yes I have a few friends who've DIY'd CO's. ITs a good option mainly for cars where you can't buy what you want.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Yeah, don't know why it auto corrected that way. I thought it would work for the rear of the e39, since most coil overs out there can't handle or are not designed for the weight.
    Sent from my SM-G930V using Tapatalk
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    All coilovers out there are designed for the weight. That’s why they make them. I can’t think of why someone would want to do this.
    Quote Originally Posted by killian665 View Post
    Some people have trouble with the Fortune Auto and Broadway, being way to soft damping. Have to use 10k or 12k springs, which feels like riding a hard tail.
    Mar 2010
    Well. There are cases where the rear setup is not a strut, and the shock doesn't ride inside the spring, and has a separate mounting location.
    Examples in my driveway would be:
    E46 - springs and shocks not concentric
    E39T - shocks in a kooky 'laydown' location to make for more cargo room
    In those cases, forcing a true C/O in the rear may be an engineering mistake, because the shock mount locations are not engineered to carry the full weight of the car, all the time, but are only intended to carry the load of the shock dampening oscillations. Which might be momentarily high but can also be negigible for long periods. Furthermore, the angle of the shock, when fitted with a spring, may do weird things to the expected spring rate and compression, whereas for the shocks they are engineered to match the wheel-travel-to-shock-travel parameters of the location.
    I suspect that's why the Fortune rear E39 touring C/O's were not a 100% success and why some did not think they were that great and why Fortune pulled them. Basically I wouldn't rush in to force a C/O into a place that isn't meant to take all that load.
    To try that with an E46 shock location for instance - total idiocy, you're begging to ram the C/O up through the shell in no time unless you welded up a new custom shock tower or at least reinforcement plates that are far beefier than the usual "heavy duty shock mounts'. Even the bottom shock mount to the rear wheel carrier point is questionable whether it should carry all that load. I know there are E46 fanboiz who do this but I think they are stupid - there's no engineering benefit from forcing it into a C/O strut configuration, although probably many of them like the bling factor of peering in and seeing a C/O type sexytime setup instead of just a shock + a spring.
    IF however you are self-fabbing a C/O to replace an existing strut-type suspension, and doing so because it'll get you something you can't get otherwise easily, then its a fine idea.
    2003 M3CicM6 TiAg
    Former:
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Yeah I’m not talking about trying to bolt a strut to the back of an e46. Nobody does that. Or at least I’d imagine nobody would.
    I mean why would you need to make your own like this when almost every company makes a kit for these cars. If you’re having problems with damping just have them revalved properly or buy a better set up. Upping the spring rates isn’t going to solve bad dampers.
    Mar 2010
    They do. Not many but a few poser boys who think if its not a CO-strut-design its not racecar.
    I tend to agree that there's not much sense in making your own Koni based C/O's, unless you think you have some secret sauce for requesting custom damping rates from them and pairing with some custom spring rate. A load of the 'brands' that you find will be secretly using Koni dampers inside anyway. A tiny fraction of the "COILOVER BRANDS" actually make dampers, they buy that crap from the big shock makers and stuff it inside uprights they have fabricated (and pair with springs they don't make either, but buy from Hyperco or Swift or Eibach or whoever...).
    As said before, for most part you're right, for street driving guys self-fab is silly, but yes, there are people who could have legit reasons for wanting to custom build.
    2003 M3CicM6 TiAg
    Former:
  1. Koni coilover question
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 06-24-2001, 10:42 AM
  2. Koni Coilovers vs. Dinan Stage III
    By Gatorbait in forum 1992 - 1999 M3 (E36)
    Last Post: 06-19-2001, 12:35 AM
  3. Koni Coilovers or Dinan Stage Whatever?
    Last Post: 05-26-2001, 09:13 PM
  4. Anyone have experience with Koni Coilovers or FK C/Os?
    By Scott Yu in forum 1992 - 1999 M3 (E36)
    Last Post: 05-10-2001, 02:04 AM
  5. Suspension Q: Anyone try Koni Coilovers?
    Last Post: 03-28-2001, 10:36 PM
