Results 1 to 13 of 13
Thread: FOR SALE: 1981 323i, LOTS of parts
    Jun 2003
    Eugene, OR USA
    '81 323i, 97 540i
    Time has come for me to leave the vintage BMW fold. At least for now. Car hobby and business has taken me in a different direction. So, it is with mixed emotions that I present the following for your consideration:
    The Car: (pictures below) 1981 323i. Modified for fast road use. 2340 lbs. Very nice bodywork. Never hit. M20 with chip, headers, aluminum flywheel. Spartan interior. Hard springs & bushings. Genuine BMW Motorsport quick ratio steering rack [2.4 turns lock-to-lock]. Coilovers. G245 5 speed, NEW driveshaft, guibo. Adjustable rear subframe. 3.45 LSD, recently rebuilt by trans & diff specialist. Lots of new body rubber, lenses, etc. Like new Sparco Evo GRP fixed-shell seats. Custom DOM 6-point roll bar. No cup holders. No radio. No AC. No PS. NO BS. Guaranteed to scare your mother. With some detail finishing, this car can be a very nice outlaw-type street machine, or take it ‘the rest of the way’ for serious track work.
    Buy the car for $9323. Or buy some parts, list below. Or make me an offer on the whole ball of wax.
    THIS CAR HAS BEEN SOLD. Thanks for looking! Still have lots of parts for sale - see below:
    Details:
    VIN 7243543
    Powered by M20B25 from late 325is, with factory oil cooler, braided Setrab lines and threaded AN fittings
    • Shorty headers
    • Aluminum oil pan in PERFECT condition, with Ireland Engineering baffle
    • 173 ECU with chip
    • New K&N cone filter
    • Aasco aluminum flywheel
    • Ron Davis aluminum radiator
    • 19” Spal electric fan
    • Original 2.3l motor stock, complete from air box to exhaust manifolds available. This motor is strong and runs reasonably clean. Head rebuilt
    Suspension:
    • Ireland Engineering coilover conversion on shortened 323i strut housings with Koni adjustable dampers, 2.5x8 Hypercoil 450 lb springs
    • Ground Control aluminum camber plates
    • Urethane bushed control arms
    • 28.6mm front anti-sway
    • Original BMW Motorsport quick ratio steering rack
    • Aluminum strut tower stress bar
    • Alpina copy lower chassis tie bar
    • Rear suspension mounts to Dinan adjustable subframe with solid chassis mounting
    • Coil over conversion to Bilstein Sport dampers, 375 lb springs
    • Ground Control upper shock mounts.
    • 19mm anti-sway on urethane bushings and spherical bearing linkage
    • Urethane trailing arm bushings
    Recently rebuilt 3.45 LSD
    Slotted and cross drilled rotors with Axxis Deluxe pads
    Braided flex brake lines
    Trunk mounted Optima battery in Top End rear strut brace
    Motorsport replica mono wiper conversion
    Wheels are Konig Imagine 15x7 et20 with 205/50 Dunlops
    Custom 1.75” DOM 6-point roll bar
    Sparco Evo fixed-shell seats
    Momo Corse wheel
    Parts Sale: Please note - much of this inventory has not seen daylight in years. It is stored in my basement. I will add photos to this post during the next few days. Please be patient: it will take some time to dig things up!
    • Fuel pump, in-tank, NOS, with harness, hoses. TWO complete sets. $200/set
    • Fuel & Ignition components, e30 325i, intake manifold, rail, injectors, eng harness, sensors. $100.
    • Complete running engine: e21 323i M20 6 cyl., complete, air box to flywheel. Strong! $750.
    • Front struts, e21 323i, uncut housings, with OE bearings, hubs, Bilstein sport shocks. $200. SOLD
    • Front struts, e21 323i, uncut housings, w/Bilstein sport dampers. $200.
    • Complete disassembled engine, e30 Eta M20 6cyl. 180k miles. Nice. $100.
    • Cylinder head, e30 “i”, 731 casting, complete. $150. Repairable damage to #6 combustion chamber.
    • Cylinder head, bare, e30 “i”, 731 casting $75. SOLD
    • Oil pan, e30 M20 6 cyl., alloy. Some scuffing, otherwise very nice. Drain plug thread repair done. $200.
    • Dash, e21 post facelift [late], CRACK FREE. $500. SOLD.
    • Dash cover. Fabric, black, with bound edges and embroidered BMW logo. Very nice. $50.
    • Dash cover. Conceal those cracks with an OEM look molded cover. With adhesive. Unused. $50.
    • Steering rack, e21 323i, with damper. $75. SOLD
    • Rear subframe, e21, unaltered. $150.
    • Oil pan, e21 323i, steel, nice. $100.
    • Brake rotors, e21 323i, set of four, OEM, very nice. $75/set. SOLD
    • Sport springs, for e21, H&R, set of four, nice, very clean. $150. <<<SOLD>>>
    • Headlight grilles, e21 late, post facelift, two sets. $25/set. ONE SET SOLD
    • LSD, e21, 3.91, nice, clean, quiet. $750. SOLD
    • Flywheel, e21 323i, nice, zero damage. $100.
    • Shocks, rear, e21, Bilstein Sport, 2 sets, nice, clean, as new. $75/set.
    • Screen washer bottle with pump, e21, nice. $25. SOLD
    • Wiper arm linkage, complete, e21. $25. SOLD
    • Intake manifold, e21 323i M20 6 cyl., nice. $50.
    • Valve cover, M20 6 cyl., from e21 323i, nice. $75.
    • Heckspoiler, e21, Zender, complete, intact, no damage or mods. Nice. $100. SOLD
    • Wheel set: Alpina (genuine), 4x100, 15x7 et 13. Genuine. Refinished in silver power coat. No center caps. No damage, very straight, very nice! $800. <<<SOLD>>>
    • Wheel set: BBS, 4x100, 15x6 & 15x7, et13. Genuine. Older refinish, still fantastic. Curb rash, one spot on one rear. Missing two center caps. $800. <<<SOLD>>>
    • Drive shaft, e21 323i. One noisy joint - good core for rebuild. $100. SOLD
    • Misc parts. Large box. Many new, some OEM. Used parts are all good, working, clean. Small interior & exterior bits, electrical, tune-up, & small engine parts. Some glass seals. Inventory to come.
    A note about shipping: PLEASE don't ask me to quote your freight. I am short on time. I will, of course, help with this kind of thing with an accepted offer to buy. If you are interested in any of the above, then I think you know roughly how large the part is and roughly what it weighs.
    Thanks for looking. I have fallen out of the Bimmerforums habit, but will try to check this post at least twice a day. Meantime, if you want to reach me directly, please use email: blair@rocketworkscars[dot]com or give me a call: [541]5five6-314three.
    Cheers,
    Blair Winter
    Eugene, Oregon.
    Blair
    Eugene, Oregon
    Portland, OR
    1982 323i 2003 325it
    (Incoming thread jack)
    Whose POS red car is that in the back?? Probably some HACK kit car...
    GTWA, Blair!
    Iíll let you know if I need anything...
    Past, Present, and Future
    1974 BMW 2002tii (RIP)
    1995 BMW 325is w/ FULL S50 swap, track prepped (SOLD)
    1988 BMW 325ix Zinno/Black (RIP)
    1988 BMW 325ix Alpine/Black (Sold)
    1988 BMW 535is Alpine/Pacific Blue (Going Away...)
    1982 BMW 323i (Current Project/Paper Weight)
    2003 BMW 325i Sport Touring (Daily Driver)
    Feb 2008
    NY
    Did you ever dyno the car as it is now ? Interested to see how the afm and chip compare to a miller maf conversion.
    Beaufort, SC
    81 C1, 89 ix, 76 02
    pm'd on the Alpina wheel set
    Houston, Tx
    '78 320i
    I really want a 320 / 6 now. I just need to finish my project so my eyes quit wandering.
    Just out of curiosity, based on what youre asking and the quality of the car, did you consider BAT? I always wanted to participate on that, at the other side of the coin I dont think I could put up with the peanut gallery of BAT commenters.
    Portland, OR
    Quote Originally Posted by jaredmac11 View Post
    I feel like Blair's car would do well on BAT... I was thinking about selling my '88 535is on there, but its far from perfect, and i always envisioned the commenters as angry villagers with torches and pitch forks, so I'm trying to sell it locally.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Wooden Pitch Forks, circa 1500's
    Randy
    Jun 2003
    Eugene, OR USA
    '81 323i, 97 540i
    Quote Originally Posted by m60b30530i View Post
    I haven’t had the car on a dyno since the swap, but this is a pretty common cocktail. If I were estimating, I’d figure around about 185 to 190 at the crank.
    Cheers,
    BW
    Blair
    Eugene, Oregon
    Jun 2003
    Eugene, OR USA
    '81 323i, 97 540i
    Hi Jared,
    I’m with you (and Morty) - I dig BaT but I don’t relish the idea of selling a car there. Its a tough crowd for sure!
    Its my first cup of coffee ritual though, checking BaT.
    Cheers,
    BW
    Blair
    Eugene, Oregon
    Jun 2003
    Eugene, OR USA
    '81 323i, 97 540i
    The car has been sold. There arestill plenty of parts available tho...
    Blair
    Eugene, Oregon
    May 2018
    Santiago, Chile
    1983 BMW E21
    I would love to by the e21 323i M20 6 cyl., but i'm too far away (Chile!), so shipping would be quite expensive ... or not?
    Jun 2003
    Eugene, OR USA
    '81 323i, 97 540i
    Parts List updated with recent activity . Thanks again for looking!
    Blair
    Eugene, Oregon
    Vienna, Virginia
    Bmw 323i e21
    Pm'd on one of the Bilstein Sport Rear sets and the ETA Engine.
  1. E46 2005 330ci M-Sport for sale in Florida: lots of pictures
    By johne in forum 3 series & Z Series
    Last Post: 03-04-2011, 04:53 PM
  2. Original 1981 323i lots of pic`s
    By larsnjo in forum 1975 - 1983 (E21)
    Last Post: 08-05-2009, 01:09 AM
  3. E30 Convertible for sale in NorCal.. lots of new parts!
    By skyse30 in forum Wheels and Tires
    Last Post: 10-07-2006, 04:26 PM
  4. Parting out my E39. Lots of parts for sale.
    By Marcus-San Diego in forum 1996 - 2003 (E39)
    Last Post: 10-01-2002, 12:30 PM
