I've installed the NBT in my 2001 E38, but need the NBT coded to see the DSP AMP. It plays for 2 minutes then audio drops out. Friends that have installed this say this is a good sign and that the coding is the last step.
Ive tried NCSExpert and NavCoder but for some reason I can't get on the iBus. Ive tried everything from using different OBD2 connectors to new cables, my hope was that I could code it off on the "car' side, but it seems that the final piece is with coding the NBT.
My NBT is wired with the ethernet Cat5 cable, so itd be easy to pop onto TeamViewer and knock it out.
If anyone has a few minutes to help make the adjustment, Id be thankful!
2001 | DINAN 7 Sport | S62 Swapped 6-Speed
DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
Dual Pane Glass | Black & Sand Int.
2001 | 750iL | AlpineWeiss III
@scotthduke on Instagram
Solved.
Glad you got it done
Instagram.com/nordmanmg
Your current situation is not your final destination
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
Yeah. I was hitting the wrong button on NCSworks when trying to load the profile and go in the the ZCS/IKE. Id never used it. The coding that has
to happen is on the DSP AMP, not the NBT. One setting has to be changed and thats it.
The NBT requires some minor coding to get the car's temperature readings back on the Fahrenheit scale, but no big deal there.
So how much was the damage for the set up
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Ebay and LKQ via ebay.
$80 Controller (came with full wood console from donor car)
$200 for NBT
$280 for brand new F16 glass 10'25 screen (in original box)
$1000 harness
$1560
+ 200 if you include the monsoon upgrade. I had not choice there, my speakers were dust. Literally.
Not bad if you have the 16:9 setup and DVD Nav to sell off, really helps offset the cost.
yea it was out of the 15' M5 that donated my NBT, thanks for the info on the bezel.
DINAN Springs, Throttle body, Intake, CAI, MAF & Exhaust / Powder-coated Valve Covers & 750 brakes up front. Brand New M-Pars, Monsoons, NBT ready to install
Time to revise your signature!
