Results 1 to 15 of 15
Thread: BMW-Sys - NBT - Retrofit - Coding Help - E38 - Teamviewer, perhaps?
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    I've installed the NBT in my 2001 E38, but need the NBT coded to see the DSP AMP. It plays for 2 minutes then audio drops out. Friends that have installed this say this is a good sign and that the coding is the last step.
    Ive tried NCSExpert and NavCoder but for some reason I can't get on the iBus. Ive tried everything from using different OBD2 connectors to new cables, my hope was that I could code it off on the "car' side, but it seems that the final piece is with coding the NBT.
    My NBT is wired with the ethernet Cat5 cable, so itd be easy to pop onto TeamViewer and knock it out.
    If anyone has a few minutes to help make the adjustment, Id be thankful!
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    Mar 2011
    Greenville, NC
    Solved.
    2001
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Glad you got it done
    Instagram.com/nordmanmg
    Your current situation is not your final destination
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Quote Originally Posted by 740ilDuke View Post
    Solved.
    So your NBT is fully working?
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
    Mar 2011
    Greenville, NC
    Yeah. I was hitting the wrong button on NCSworks when trying to load the profile and go in the the ZCS/IKE. Id never used it. The coding that has
    to happen is on the DSP AMP, not the NBT. One setting has to be changed and thats it.
    The NBT requires some minor coding to get the car's temperature readings back on the Fahrenheit scale, but no big deal there.
    Quote Originally Posted by Sabreslight View Post
    2001
    Dec 2009
    Dallas,TX
    Awesome, I've got some questions if you don't mind?
    Sent from my SM-N950U using Tapatalk
    Mar 2011
    Greenville, NC
    Fire away.
    2001
    NYC
    99 IL/13 SXT/04 Audi A4
    So how much was the damage for the set up
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
    Mar 2011
    Greenville, NC
    Ebay and LKQ via ebay.
    $80 Controller (came with full wood console from donor car)
    $200 for NBT
    $280 for brand new F16 glass 10'25 screen (in original box)
    $1000 harness
    $1560
    + 200 if you include the monsoon upgrade. I had not choice there, my speakers were dust. Literally.
    Not bad if you have the 16:9 setup and DVD Nav to sell off, really helps offset the cost.
    Quote Originally Posted by franco90 View Post
    2001
    NYC
    $200 for NBT
    $1000 harness
    $1560
    Nice score Scott
    El Cid 1999 IL
    Dec 2009
    Dallas,TX
    $200 for NBT
    $1000 harness
    $1560
    Not bad at all, i'm just about at the same price point although i got my screen for free...did you just get the harness from theshafro? and did it include everything needed outside the aforementioned hardware?
    Mar 2011
    Greenville, NC
    That is correct.
    Nice score on a free screen!
    The screens are different depending on what they come out of, I took mine and removed the plastic housing and then used silicone to mount it inside the
    trimmed out 4:3 bezel. That takes a good bit of dremel work.
    2001
    Dec 2009
    Dallas,TX
    yea it was out of the 15' M5 that donated my NBT, thanks for the info on the bezel.
    Houston, Texas
    1995 Dinan 740il
    DINAN Springs, Throttle body, Intake, CAI, MAF & Exhaust / Powder-coated Valve Covers & 750 brakes up front. Brand New M-Pars, Monsoons, NBT ready to install
    Time to revise your signature!
    Mar 2011
    Greenville, NC
    good point!
    Quote Originally Posted by Grady in Texas View Post
    2001
  1. Bluetooth oem retrofit coding help
    By davesd in forum Diagnostic Software
    Last Post: 09-02-2017, 06:00 PM
  2. BMW 323i 2000 error codes Help!!
    By Nikehustle111 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-14-2012, 01:44 PM
  3. Bmw e36 oem radio code help
    By pearl325 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-02-2011, 09:21 PM
  4. Replies: 10
    Last Post: 05-31-2008, 09:45 PM
  5. Man, stevens creek bmw wants $40 to get my radio code.. help please~~
    By manuelku in forum California sponsored by Avus Autosport
    Last Post: 06-21-2006, 07:44 PM
