Results 1 to 4 of 4
Thread: 1jz e36 Driveshaft length
    Feb 2013
    Long Island N.Y.
    2002 530I
    How's it going guys? Was wondering if anyone has any info on the length of the driveshaft for a 1jz e36 with the r154 tranny. .. I've been told to put the engine and tranny in the car and measure it... trust me, the thought did cross my mind, but have the rear end off the car to replace all the bushings and adding the reinforcement plates...
    I know this swap has been done a million times over... but there's really no info on the length of the driveshaft out there... it's crazy. ..lol.. So if anyone out there has access to this info... can you please help me out. ..
    Almost forgot. ..I know it depends on the mounts your using, but there's not much difference in the mounts. .. you can pretty much move the engine forward or back, depending on what you need. .. any help will be appreciated. Thanks
    Dec 2013
    Raleigh
    1993 325is
    get your rear end in and measure from output shaft flange face to diff flange face, call up driveshaft shop and tell them the length in inches and what transmission and rear end your using. then decide if you want steel, alum, or carbon fiber shaft. theres no set driveshaft length as it differs depending on what mounts you use.
    Jan 2014
    SF, CA
    S/C LS2 e46, LS e367&8
    Quote Originally Posted by glockroulette View Post
    Exactly. Even in LS swaps it differs.
    Mar 2018
    Arizona
    1998 328I
    I woudn't risk it, wait till rear end is back in and measure
  1. Cxracing motor+transmission mounts driveshaft length e36?
    By Daniils in forum Engine Conversions
    Last Post: 08-26-2017, 04:25 PM
  2. E36 ls1 swap driveshaft length
    By AdamE36M in forum Engine Conversions
    Last Post: 11-20-2014, 12:22 PM
  3. E36 WTB: e36 Driveshaft (4 bolt rear)
    By pandaboo911 in forum BMW Parts Wanted
    Last Post: 02-14-2013, 08:30 PM
  4. E36 BNIB OEM E36 driveshaft center support
    By racepar1 in forum Drivetrain & Transmission Parts
    Last Post: 05-25-2012, 02:49 PM
  5. E36 E36 Driveshafts (manual, auto, m3, non-m, 4 and 6 bolt)
    By SQ Bimmer in forum Drivetrain & Transmission Parts
    Last Post: 01-07-2010, 09:15 PM
