Results 1 to 12 of 12
Thread: Temp gauge
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    Temp gauge
    What would cause my temp gauge to Kenneth self all the way hot come back to the middle pain itself again and then again one more time and keep doing it???
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Mar 2017
    Adelanto California
    2000 BMW 528i
    Quote Originally Posted by 300kplus View Post
    It depends. Does it go hot when applying gas or when idle? Explain thoroughly what happens before and after the symptoms show up
    Sent from my SM-G955U using Tapatalk
    San Jose, CA
    1997 BMW 540i 6 speed
    "Kenneth self" ​What does that mean?
    Quote Originally Posted by edjack View Post
    Sorry guys. Voice texting SUUUUUUUUCKS!!!!
    Okay so let me start over and I can I'm voice texting so I will proofread it this time as last time I was driving and I panicked when it did that.
    The car is missing I'm getting ready to put plugs in. I pulled codes and number 4 is misfiring. The temperature gauge goes all the way and pins itself to the right hot position period then it comes back and does this again repeatedly three or four times. I'm getting ready to look in the radiator and to check the level after it has cooled off which will be soon. That's it that's what happens. Thanks again guys oh yeah one more thing sucks sucks sucks :-)
    Supplement to TEMP GUAGE
    After I pulled codes and found out number four was misfiring,
    It wasn't a constant misfiring but the temp gauge needle did the same thing a couple times. This time it is a constant mess which started on a drive of about 14 miles. So with a constant or with an unnoticeable Miss, this scenario has happened twice now...
    Is this characteristics of a thermostat going bad? It's one of the only thing I've never changed relative to the cooling system
    San Jose, CA
    I suspect the dual temp sensor.
    Get a new phone. My Moto G4+ Droid has a flawless dictation function. I simply don't use the keypad, unless I sometimes need to correct text.
    Hahaha! Yeah... Got'cha!
    Where is the dual temp sensor located? Can you go after market on it and if so what brands please?
    San Jose, CA
    It's in the top of the 'stat housing. Most BMW online stores carry reputable brands.
    A bad 'stat will not cause an instantaneous event.
    Thanks for this.
    I discovered my pressure release switch for my A/C system was blown. Replaced it, had the system vacuumed down & recharged. My car has seemed to "correct" itself??
    She is definitely running the way she did b4 the work...
    I will OFCOURSE monitor the behavior but will be replacing the spark plugs soon...
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    The car is missing
    Call the police and have them put out an APB.
    Hopefully the plugs fix the misfire. If it comes back, suspect the coils and coil boots.
    Re: the temp gauge.... do you mean it would slowly go up as car warmed up then come back down etc? Or it would cycle sweep left/right/left/right immediately? If the latter, certain electrical short circuit or low voltage issues cause the cluster to do that. I think it's a failsafe alert thing to indicate "HEY SOMETHING ISN'T RIGHT HERE". Either that or its some component failing to be able to power up completely. Either way, it means "short or no batter power" usually. Maybe your AC switch was somehow shorting out something else? That's not an unreasonable hypothesis.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Gotcha Gotcha, Thanks!
    I think it's tied to my parasitic battery drain and I've been chasing down periodically. Very very strange it comes and goes. Sometimes the car goes to sleep, sometimes it doesn't.
  1. temp gauge question, please help
    By Rahul325 in forum 1991 - 1999 (E36)
    Last Post: 10-01-2001, 05:03 PM
  2. Temp Gauge behaviour
    By Jason in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-27-2001, 05:57 AM
  3. Need help with Oil Temp Gauge
    By Seedster in forum 1992 - 1999 M3 (E36)
    Last Post: 07-02-2001, 09:17 PM
  4. Need help with Oil Temp Gauge (please!)
    By Seedster in forum 1991 - 1999 (E36)
    Last Post: 07-02-2001, 06:48 PM
  5. Replies: 4
    Last Post: 05-10-2001, 09:16 PM
