Results 1 to 6 of 6
Thread: Installed used brake master cylinder and fluid not bleeding out!
    South Jersey
    84 318i
    I installed a used master cylinder on my 86 325es and when I went to bleed the brakes fluid is only coming out of the driver's side rear caliper! If the master cylinder is bad would it cause this? Or is it just a large air pocket possibly? I am using a vacuum bleeding and had a friend also pump the brakes!
    Sep 2014
    KS
    e24e30e36e39e90
    Are you sure the bleeder valves aren’t clogged?
    South Jersey
    84 318i
    I will check that when I get home, good idea. They put some much road salt around here in the winter time. If a master cylinder is bad would it cause the system not to bleed even with a vacuum pump?
    Sep 2014
    KS
    e24e30e36e39e90
    I had a clogged one on my e36, stick a wire through or unscrew it completely.
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    Did you bench bleed the replacement master cylinder? Look up the procedure.
    South Jersey
    84 318i
    I didn't bench bleed it. I cleaned the bleeder valves and fluid is coming out now. I noticed my fluid reservoir is not all the way in the master cylinder where it meets the rubber bushings. When I try pushing it down it won't go all the way in the rubber bushings. I bought new rubber bushings.
  1. E30 Brake booster, master cylinder and fluid reservoir off a 91 318is
    By IWannaBMW in forum Brake Kits, Rotors & Pads
    Last Post: 09-02-2011, 06:36 PM
  2. Brake Master Cylinder and Fluid Bottle on Ebay
    By jchristians in forum 1975 - 1983 (E21)
    Last Post: 11-22-2008, 07:48 PM
  3. E36 M3 Brake Master Cylinder and Brake Booster
    By redrocket328 in forum Brake Kits, Rotors & Pads
    Last Post: 03-29-2007, 11:51 PM
  4. WTB: New or Slightly Used Brake Master Cylinder for 95 M3
    By 95DinanM3 in forum BMW Parts Wanted
    Last Post: 02-20-2006, 02:46 PM
  5. FS: 99 M3 brake master cylinder and booster
    By spIkee36 in forum BMW Parts For Sale
    Last Post: 10-15-2005, 11:06 PM
