Hello All. First time poster here. I've owned a 2007 328i since new. About 5 years ago, I started experiencing a strange, intermittent problem with operating the rear driver's side window. It will go down normally, but refuse to come up. It will make a brief effort, the glass moving perhaps a quarter inch, but fail to go up, then retract fully to the down position. I will try opening and closing the door, operating it from both the driver switch, and from the rear window switch. Same result. Then, about the time I am ready to give up and take it to my mechanic, it will miraculously start working again. It checks out completely normal, no faults shown on the computer diagnostics, etc. I have not had them take the door apart, and am reluctant to start randomly replacing expensive parts in a "shotgun" approach. It happens infrequently, about once a year when it first started, but now 3 times in the last six months.
Any help in solving this mysterious problem greatly appreciated!
What are the sounds when you attempt to raise the window and it refuses to go up? This will tell us if it’s a mechanical or an electrical issue. That is, it’s likely a mechanical issue if you can hear the motor trying to raise the window, while if it’s all quiet the issue is likely electrical.
So, no noise after the “thunk.” When the window is operating normally does it’s sounds differ from those of the other rear window? Does it sound like it’s binding? Is it slower? How far up does the glass move before the “thunk”?
The lift mechanism is pretty simple. Here’s the link to it:
http://www.realoem.com/bmw/enUS/show...diagId=51_5731
I’m wondering if the lift assembly motor is stopping because it senses the window jamming even though, from your description, it’s not.
+1
Normally when those window regulators start to crunch or pop, they are on the way out. The cable has a plug built on the center of it, and that connects to the mech. If it slips out, then the window will stay in place and the motor will go the rest of the way.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Correct. No noise after the "thunk."
When the window operates (99 precent of the time) it sounds perfectly normal, and operates with the same speed and smoothness as the rest of the windows. No sign of binding, or any abnormality. Then, when the gremlin goes to sleep, usually after a few hours of frustration, it resumes normal operation.
The window moves perhaps 1/4 inch when it tries to operate. You basically have to look down into the slot to see it move. Barely comes up even to the top of the rubber rain fairings.
My mechanic also suggested it could be sensing a blockage and activating the self-arresting safety feature. Is there a fix for that?
In searching the archives on other parts of the forum, I saw a reference to some sort of "cable regulator" that I did not see referenced in the window schematic. Any thoughts on that?
Thanks in advance!
That is the most common failure on the window regulators, and the electric motors are very quiet. I will see about taking a picture and posting it up on one of the front regulators that has failed, and how it relates to the rears.
Darin
Current:
Past:
M-Flight Member
#1 in the diagram is the regulator. 98% of the time, it's the culprit.
Chris Powell
BMWCCA 274412
I'm gonna say its the motor. He said most times, it works fine. We all know a broken regulator will not work ever. Sounds like the motor is activating anti-trap.
Darin
Current:
Past:
M-Flight Member
You could attempt what is normally a preventive measure related to maintenance, and it might help, if it's related to some blockage due to a resistance coming from the rubber window frame (triggering the regulator):
1) take the window all the way down
2) thoroughly clean the inside of the window frame with a DRY used toothbrush to get rid of all the dust accumulated over time (it tends to become compact and sticky with water/time)
3) spray some silicon lubricant such as this one, inside the window frame:
https://www.wd40specialist.com/produ...one-lubricant/
4) take the window back-up
5) repeat 1) and 3). it'll help the silicon get to the invisible parts of the frame and lubricate it slightly.
If you feel like going a step further, remove the door panel and put some (not too much, for e.g. use a cotton bud) transmission fluid on the cable while operating the window up and down, to help it get to the motor.
Edit: when you're done, wipe off any silicon accidentally sprayed on the car's paint, as it might have a corrosive effect.
I was thinking that the little metal crimped chunk (splice?) in the middle of the cable was occasionally hitting an obstruction, as it has on my own M5 and several other cars I've worked on, thereby causing the anti-trap function of the motor to function. You know those little tabs, which keep the cable tucked tight to the main body / upright of the regulator? I know not all regulators have these...E39's do, E46's don't, I can't recall if I've ever seen them on an E90 or not.
Still, I have seen the motor fail more often on E90s than any other BMW....
Chris Powell
BMWCCA 274412
