Results 1 to 7 of 7
Thread: E30 Trunk Jammed
    Apr 2018
    Salt Lake City, Utah
    1985 BMW E30
    Unhappy E30 Trunk Jammed
    My trunk was jammed and would not open, I looked around online and many said to go through the inside ski pass and remove the 10mm holding the latch. So I did and still no luck, what could be the issue? The car has been sitting and the battery is dead.
    Dec 2014
    Springfield, VA
    1992 BMW 318i
    Quote Originally Posted by dnying View Post
    Open gas tank door, push lock to side until it disappears into the body, open trunk.
    Apr 2015
    Toronto
    e30s
    There is a rod connected to the trunk latch from the inside. You may be able to dislodge it when pulling the trunk lock out from the outside. The point of removing the the 2x10mm bolts is the losen the trunk lock to be able to pull out from the outside. Then you reach into the hole and there is a lever you push to the side and that will release the trunk.
    Dec 2014
    Springfield, VA
    1992 BMW 318i
    Check and see if your gas tank door cover is unlocked and the gas tank door is open. If so, depress the lock. This should unlock the trunk.
    Apr 2015
    Toronto
    e30s
    ha!! I had no idea that works!! nice trick...thanks for that!! :-)
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    dude, if that works, that is badass. I would have never thought of that
    No e30s again.
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    Another thought. Could you use jumper cables at the battery junction under the hood and release the electronic lock that way?
    2004 525i Sport, Manual - 1985 325E Coupe Manual
  1. E30 WTB: e30 Trunk BRA!
    By Coletown in forum BMW Parts Wanted
    Last Post: 08-11-2012, 04:19 PM
  2. E30 E30 Trunk Lid, Cosmo Blue good condition
    By jas67 in forum Exterior Lighting & Body Parts
    Last Post: 07-06-2011, 09:33 PM
  3. E30 FS: BMW E30 Trunk Roundel
    By DeM3n in forum E30 Parts Classifieds
    Last Post: 09-26-2009, 10:56 PM
  4. E30 WTB: E30 trunk latch assembly
    By az3579 in forum E30 Parts Classifieds
    Last Post: 01-16-2009, 10:13 PM
  5. E30 FS: E30 trunk spoiler, tails & more
    By 525fourthew1n in forum E30 Parts Classifieds
    Last Post: 12-19-2008, 07:58 AM
