Results 1 to 3 of 3
Thread: E30 M20 silicon hose compatible with e34?
    Apr 2014
    gold coast
    97 e36 323i executive
    I am looking at buying new hoses for my 1988 e34 which is equipped with an m20b25 engine. i was hoping to replace the rubber with silicon but cannot find a kit that specifies its compatibility with an e34. on inspection the hoses appear to be similar if not identical but i figured there may be differences i haven't noticed. are there differences between the coolant hoses of the e30 and e34? thanks
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I am going to say maybe. Now the ones that are engine specific, say from the water pump to the thermostat housing sure. Anything else will be a shot in the dark as the motor in the E-34 will sit further away from the radiator. But if you really want to know for sure, use the cross index here: http://www.realoem.com/bmw/enUS/show...diagId=11_0794
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    NW suburban Chicago
    hiss by my window
  1. CD 43 compatible with E34?
    By djregister70 in forum 1988 - 1996 (E34)
    Last Post: 03-13-2018, 07:18 PM
  2. E30 Center Vent Compatible with E34?
    By mdimillo in forum 1988 - 1996 (E34)
    Last Post: 09-19-2013, 01:48 PM
  3. E30 M20 ECU/DME Compatibility
    By DmcL in forum 1983 - 1991 (E30)
    Last Post: 03-04-2010, 06:22 AM
  4. Are E28 rear end bushing compatible with E34?
    By herman maire in forum 1988 - 1996 (E34)
    Last Post: 12-10-2005, 09:41 AM
  5. stock m3 flywheel compatible with e34 m5 clutch?
    By Serious in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2004, 02:03 AM
