Results 1 to 3 of 3
Thread: M52tu microfilter air problem?
    Nov 2016
    texas
    1998 328is
    So when I first got this car it had long term fuel trims of 3% so I assumed it is normal because the PO didn't toutch any of the lines , so when I went to change both cabin air filters that require you to take out the microfilter assembly I finished the job put them back on and now the ltft for both banks are about 11% I double checked if they were in good and they are, could a vaccum leak come from that location? Haven't toutched the intake boot or any of those lines yet. Wanting to take care of the leak so I can save my catalytic converters.
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Not from the microfilter area itself. I would look for any vacuum lines that may be near by that may have or could have gotten disturbed.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Not sure (without googlin' the pixozrz) where it sits on an M52TU car, but, the brake booster "sucking jet pump" device is notorious for sneaky cracking and leaking while still looking like it is whole to the casual eyeball. Inspect that guy - at least on the V8 that's pretty much in a spot where you'd whack it if you took out the cabin air elbow ducts (which shouldn't have been necessary to just do the filter, but I take my trays out when I do the filtters anyway to wash them down and check the bins below for debris etc. )
    Oh and BTW, don't sweat the cats/O2's too much. I mean the idea to fix and corral trims back is 100% correct, but as long as you're not getting codes and lights, then it means the DME is currently able to trim out the fuel to a good point, therefore the O2's and cats are not actually seeing too lean/rich conditions because the trims are 'working'.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  1. chrome lip with ocean air..problems
    By live2roll in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-13-2008, 08:34 PM
  2. Passenger Microfilter Air Channel
    By blueMRoadster in forum 1996 - 2003 (E39)
    Last Post: 12-10-2007, 11:54 AM
  3. Please! difficult secondary air problem
    By vml in forum 1991 - 1999 (E36)
    Last Post: 08-17-2007, 12:00 PM
  4. 1998 323is Air problems
    By abbaZaba in forum 1991 - 1999 (E36)
    Last Post: 05-02-2006, 02:44 AM
  5. Heater core coolant flow.. cold air problem.
    By E36DJ in forum 1992 - 1999 M3 (E36)
    Last Post: 01-29-2005, 06:21 PM
