Bavarian Soundwerks
Results 1 to 8 of 8
Thread: E36 amp wiring diagram pin out
    Miami
    Imola Red e30, Alpine White 135i
    I installed some speakers in my 97 e36 m3 the other day (non HK sound package) and I want to install and amp to power them. I already ran the RCAs and want to wire the speakers themselves now.
    My plan is to run the wires straight from the Amp to te rear 6x9s, but rather than running speaker wire through the car and into the door, disconnect the factory amp to the left of the trunk, and use those speakers to power the front components (5.25 kick panel, and tweeter in door, delete the mid range).
    Is that a bad idea?
    And does anyone have a diagram of the stock amp Pin out and wire colors?
    Thanks!
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    This should help you a bit, diagrams can be found in workshop manuals or perhaps through a Google search.
    Color Purpose
    Blue Power Antenna
    Orange Illumination
    Black Chassis Ground
    Red 12 Volt Switched Power
    Yellow 12 Volt Constant Power
    Green Left Rear Speaker Positive
    Green/Black Left Rear Speaker Negative
    Violet Right Rear Speaker Positive
    Violet/Black Right Rear Speaker Negative
    White Left Front Speaker Positive
    White/Black Left Front Speaker Negative
    Gray Right Front Speaker Positive
    Gray/Black Right Front Speaker Negative
    888.280.7799 | 6am - 5pm PST
    Miami
    Quote Originally Posted by Pelican Parts View Post
    Color Purpose
    Blue Power Antenna
    Orange Illumination
    Thanks, that seem to be the wires coming out of a standard radio harness, what I need is the wires coming out of the amp, to the speakers.
    Ill keep checking on Google but I cant find anything concrete.
    Apr 2015
    Tennessee
    1998 BMW 328i
    I just redid mine. I found a diagram here on the forums by searching thru google. If you can't find it or need help, let me know. The easiest way to do it is to cut the factory plug for the stock amp off and then reuse the factory wiring. That way you don't have to buy new wire and run it. If you get a 4-channel amp you can run your front and rear speakers off of one amp.
    These are the wire colors for the front speakers. I don't have rear speakers anymore since Im running a sub in place of them, so I didnt bother to map rear speaker colors:
    Front Right:
    Tweeter - blue/black blue/brown
    Door Panel midrange - blue/red blue/brown
    Kick panel - blue/red blue/brown
    Front Left:
    Tweeter - yellow/red yellow/brown
    Door panel midrange - yellow/black yellow/brown
    Kick panel - blue/white blue/brown
    The wires with brown stripes are the negative.
    In order to install the tweeters in my door, I had to cut the factory plug off and crimp some new spade terminals on. My 5.25" speakers in the kick panel hooked directly up to the factory wiring.
    What speakers did you install? I can recommend a good amp based on that. You want to match the RMS power of the amp to the RMS power of the speakers.
    It does get a bit confusing because there are several blue/red wires. They are wrapped in pairs, but two of the pairs are the same color. The pair for the right kick panel is longer and heavier gauge than the one for the door midrange.
    germany
    6/96 318is
    Quote Originally Posted by XnWarden View Post
    I just redid mine. I found a diagram here on the forums by searching thru google. If you can't find it or need help, let me know. The easiest way to do it is to cut the factory plug for the stock amp off and then reuse the factory wiring....
    I would find it easier to preserve the stock wiring and use an adapter, perhaps one of these.
    Dec 2017
    Houston
    01 M5, 02 330ci, 03 M3
    Quote Originally Posted by johnf View Post
    Second this. Much better practice than pulling the factory harness or plugs. Easier to modify and repair later if needed, too.
    Apr 2015
    Tennessee
    1998 BMW 328i
    That's for the head unit. I don't know of any adapter for the amplifier. And based on the designs of after market amps, I'd say it's impossible to make one.
    Apr 2015
    Tennessee
    1998 BMW 328i
    OP heres the pinout. I got two of them mixed up above it looks like
  1. e36 convertible hk audio amp wiring diagram to 8" sub?
    By Weatherman in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-01-2007, 01:27 PM
  2. E36 stock amp wiring diagram.
    By Furious in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-27-2006, 07:31 PM
  3. Help i need the stock amp wiring diagram
    By $Rich$ in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-10-2003, 11:28 PM
  4. E36 HU wiring diagram
    By ss109 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-05-2003, 12:15 AM
  5. E36 Amp Wiring Codes...
    By Kevlar in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-07-2002, 04:51 PM
