Results 1 to 2 of 2
Thread: ambient temp not showing after battery disconnect
    Sep 2017
    USA
    2001 325xi
    Hi all, I had to disconnect my battery for a few minutes..When I reconnected it, only the clock time shows in the cluster. Prior to the disconnect, I had the ambient temp showing..When I used the code to read the temp, I used 7.1, it showed the correct temp so I know the sensor is up and running..What do I need to do to get the temp display back in the cluster where it used to be?? It is not a matter of life and death, but it was a convient means of knowing the outside temp..Thanks in advance.
    zym
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Press the button at the end of the turn signal/high beam stalk.
  1. 1990 535i will not even crank after battery disconnect
    By ivan5252 in forum 1988 - 1996 (E34)
    Last Post: 09-13-2012, 10:19 PM
  2. E34 OBC not working after battery change. Help
    By mihai77 in forum 1988 - 1996 (E34)
    Last Post: 09-30-2005, 03:35 PM
  3. Relay after battery disconnect
    By Alvis in forum 1991 - 1999 (E36)
    Last Post: 04-21-2005, 01:21 AM
  4. Warning lights after battery disconnect
    By roo97ss in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-06-2004, 10:20 AM
  5. warning lights after battery disconnect
    By roo97ss in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-06-2004, 09:52 AM
