Results 1 to 25 of 34
Thread: Crank but no start nightmare...
    Apr 2018
    Va. Beach Va.
    1999 BMW Z3 Roadster
    Question Crank but no start nightmare...
    I have a crank but no start problem with my 99 Z3 Roadster 2.5L. I have a no spark condition. My fuel pump and pressure are good. I have replaced the crank and cam sensors. I had recently replaced the plugs and O2 sensors. I checked fuses and I tested to make sure that I have power to the coils but I still don't have spark. If anyone has any ideas or has come across this before please let me know. I'm running out of things to check.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Have you scanned it?
    /.randy
    Apr 2018
    Va. Beach Va.
    yes no codes and no rpms when cranked.
    Jul 2004
    Houston, TX
    36 Cylinders
    In addition to scanning the car (this case will need proper BMW diagnostic tools), what is the history to the car getting to this?
    Sounds like immobilizer to me. Someone changed the dme without much thought. That's my guess.
    You've been approaching the problem with the wrong tools.
    No RPM at all?
    Crankshaft position sensor is OE BMW or VDO/Siemens?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2007
    Great Dismal Swamp
    I'd say to bring it by and we'd take a look.... except it doesn't run.
    /.randy
    Tim @ BMW of Dallas
    98 Z3 2.8
    I was going to say, sounds like DME/EWS alignment issue. But the smart people already beat me to it.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Apr 2018
    Va. Beach Va.
    The crank sensor is an intermotor sold by O’Reilly’s and I’m probably spelling the manufacture wrong. I thought it would not even crank over if the immobilizer has kicked in.
    Jul 2004
    Houston, TX
    36 Cylinders
    Immobilizer is 2 parts. Wrong key or no key = no crank. Wrong DME = no fire.
    That being said, the immo would not simply lose sync.
    Does the check engine (SES, or whatever) light come up on initial preignition testing? Does the check engine light come up at all? Does the ECU receive power?
    I think the poor brand crankshaft position sensor is to blame. As far as sensors go, do not ever put parts store brand in it. They are not good and not built to original specifications.
    -Abel
    Apr 2018
    Va. Beach Va.
    What is needed to correct a DME/EWS alignment issue? I am new to BMWs
    Yes the light comes on
    Jul 2004
    Houston, TX
    36 Cylinders
    Diagnostic tools like in this thread http://www.bimmerforums.com/forum/sh...xperimentation
    What kind of scanner are you using? Can you confirm you have connection to the ECU?
    An immobilizer code should be set even on simple basic scanners.
    If this were my car I wouldn't focus on that path yet.
    I would ohm test the crank sensors and/or borrow a known good one from another car or a friends car.
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by dkrieg66 View Post
    And I'm not saying this out of pickiness/brand loyalty/purism. It is a VERY common problem on cheap aftermarket cam and crankshaft position sensors for BMWs, which usually have the owners do the labor 2-3 times because of a poor quality new sensor.
    I will never know why it is so hard for the aftermarket companies to replicate correctly, but it is what it is.
    -Abel
    I read, I think on here, that after production, sensors that meet OE specs go in OE boxes. Everything else goes in OEM or aftermarket boxes
    I do aftermarket for hardware, but OE for all sensors
    Dec 2007
    Great Dismal Swamp
    Yes yes. The ones that fail OE tests then get disassembled, shipped to China, then reassembled with thinner wiring, less windings in the pickup, and cheaper thinner insulation. These wivestales will never die.
    You can try unplugging something, say the MAF sensor, and see if your scanner pickups up the code. That will prove one link of the chain. But to work on these efficiently, you really need BMW specific diagnostic equipment as in Abel's link above.
    Abel is giving good guidance. I don't have anything more to add at this point. If this critter defies driveway diagnostics, it would be worth a flatbed ride over here to the swamp (Bowers Hill). I have the equipment and test specimens on hand.
    /.randy
    Redding Calif
    1999 Z3 2.5L 5sp
    Anyone actually looked at the aftermarket sensors vs the "official" ones and seen what the difference might actually be electrically? ... I'm used to Chinese parts leaving the testing to the user - much like their software... but are the failures just untested parts, or do they actually have different electrical characteristics (to save a penny here and a penny there)? ... seems a bit strange that on eBay you can buy both cam and the crank sensors for $20, yet the "official" ones will set you back $300+... that's a lot of markup or a lot of cut corners (or both).
    Apr 2018
    Va. Beach Va.
    Thanks for all the great info guys. If this doesn’t work I might just have to take that trip across the swamp to see you.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by gmushial View Post
    Yes, there is a lot of info around regarding actual measurements and comparisons. They really have different electrical characteristics.
    Apr 2018
    Va. Beach Va.
    I replaced the crankshaft sensor again with Siemens OE sensor. Same result crank no start. Any ideas on what to try next ?
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Cam sensors if they are not OE.
    Apr 2018
    Va. Beach Va.
    Yes they are BMW
    Dec 2007
    Great Dismal Swamp
    I am thinking the DME/EWS alignment needs to be checked before too much more time and money is tossed at it. What corner of VB are you in?
    /.randy
    Apr 2018
    Va. Beach Va.
    I am near the amphitheater.
    Dec 2007
    Great Dismal Swamp
    Alas, that's too far out to make on a lunch break.
    Apr 2018
    Va. Beach Va.
    If you have the tools to diagnose/fix this problem, I might be able to get it to you. I still have one Free tow from Geico ... LOL
    Apr 2018
    Va. Beach Va.
    What would cause the DME/EWS to lose alignment on a car that was running?
    Jul 2004
    Houston, TX
    36 Cylinders
    Nearly nothing.. it would have to be a serious issue.
    Scanning it with a BMW scanner and/or some logging would be a next great step.
    -Abel
  1. crank but no start 95 325is
    By ballinon831 in forum 1991 - 1999 (E36)
    Last Post: 10-20-2006, 12:20 AM
  2. crank but no start 95 325is
    By pimpin831 in forum 1991 - 1999 (E36)
    Last Post: 10-19-2006, 10:40 PM
  3. Electrical nightmare. car cranking but no start.
    By lefortez in forum 1991 - 1999 (E36)
    Last Post: 06-21-2006, 10:54 AM
  4. Replies: 3
    Last Post: 02-25-2006, 04:02 PM
  5. Need help! cranks but no start
    By ducky8888 in forum 1983 - 1991 (E30)
    Last Post: 10-28-2004, 08:32 PM
