RM European Auto Parts
Results 1 to 5 of 5
Thread: E39 Lower control arm (ball joint) is just plain stuck!
    santa rosa, ca
    1996 318is
    Angry E39 Lower control arm (ball joint) is just plain stuck!
    Hello gentlemen and ladies too,
    It's been awhile since I have posted on this site but I have run into a situation that just does not want to give.
    I have a 2000 528i E39 and I am replacing the lower controls arms due to premature wear when a new tire was placed on the front driver side and the front passenger side was over two years old. Yes we are talking shimmy especially when braking.
    I have the replacement arms and the proper ball joint separator tools but the ball joint just will not let go. I have cranked on the tool until I have very little thread showing so I know there is a lot of pressure being put on the ball joint.
    I have done this job on three different 3 series BMW's and have had some difficulty but never had one that just would not bulge at all.
    I even used the pickle fork and hammered the side of the arm but as of yet it's just plain stuck.
    Any help or ideas would be greatly appreciated.
    Thanks in advance.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Well sort of, as it been a long time since you posted.
    Yes I have seen this happen a couple of times and the only way I was able to remove it was thru heat and brute force. If you don't have a torch and a 10 lbs sledge hammer, this would be a job to pass onto a shop.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2014
    Texas
    97 528, 95 525, 03 525
    Try this. Get a ball joint remover. I have one from harbour freight. Not the best but lifetime warranty had one break on removing bmw ball joint in question. I put this tool on sometimes hammering it into place, get it really tight, then take 3lb hammer and pound top post on ball joint--yes this means hammering the beam ofvthe tool because it will be on the post. Do not have your face or anything near because when that joint releases it's like a shot gun kick.
    santa rosa, ca
    1996 318is
    Thanks for the input folks.
    I am putting this project off for at least a couple of weeks until I can build up the nerve to beat and burn.
    NW suburban Chicago
    hiss by my window
    No need for heat in my experience. If you have the ball joint tool make sure it is pushing squarely on the stud, they tend to want to walk off. Once you have cranked it down hard give the knuckle a good hard bash(don't be a pussy!) with a 3#(min) hammer. It'll let go.
    Sometimes the steel insert in the aluminum knuckle comes with it, that presents another problem. Heat then becomes your friend.
    Good luck
  1. rear lower control arm ball joint upgrade question!!!
    By deanomyte in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 08-13-2010, 01:38 AM
  2. Rear lower control arm ball joint upgrade question!!!
    By deanomyte in forum 1991 - 1999 (E36)
    Last Post: 08-13-2010, 12:36 AM
  3. Help: Rear Lower Control Arm Ball Joint
    By fatboycowen in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-09-2009, 06:17 PM
  4. FS: E36/7 lower control arm ball joints
    By confuZion3 in forum Suspensions, Springs & Shocks
    Last Post: 12-06-2007, 09:06 AM
  5. Lower Control Arm Ball Joint Removal - Help!
    By smuniak in forum 1988 - 1996 (E34)
    Last Post: 09-20-2005, 08:33 AM
