Results 1 to 10 of 10
Thread: Sticky lifter?
    Feb 2012
    Southern Ontario
    93 850Ci, 2012 X5 35d
    Sticky lifter?
    I'm about to do the valve cover gaskets and the valve seals...the car is in storage I moved it today, on start-up it had a pronounced tick, it didn't go away once warmed up...with revving a bit above idle, it has a flutter like tone...I suspect a sticky lifter...
    once I have the valve covers off, can I run the engine, to find the lifter...
    any other ideas?
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    What I have done is run a can of SEAFOAM in the oil, and started the car up letting it idle for a while. This should break up the sludge in the lifter. You can run it like that for a couple hundred miles, then do an oil change with some 0W20 - that should get rid of the ticking. The next oil change, go back to 10W30 or 40, and you should be fine.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Oct 2007
    St Albans, UK
    1991 850i 1989 325i
    I had a really loud lifter due to it being oil starved from a loose banjo bolt on the oil spray bar. I changed three of them but now regret that I didn't change all of them. They aren't expensive.
    Toronto, Canada
    BMW 850CSi
    Don’t think you can run the engine with the valve covers off unless you want an oily mess everywhere. Plus it won’t run with the intakes/injectors/DK’s/MAF’s removed.
    If you’re doing the seals, the rockers have to come out. Then the lifters basically just slide out. Replace all 24 for piece of mind.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    If you suspect lose banjo bolts, take off the valve covers. If you have some sticky valve lifter(s), then use Wynn's Hydraulic Valve Lifter Concentrate (2 cans) you don't have to change oil after that, the solution will evaporate. Or use the same amount of fresh diesel fuel. In both cases run the car warm and drive it until the noise is gone (40-50 miles) then change oil and filter.
    Jun 2012
    Uk
    1994 850csi rhd
    Mine had a similar tick, turned out to be lose banjo bolts. I fitted all new lifter and drilled and locked wired the bolts. It is something that all V12 should have done.
    Feb 2012
    Southern Ontario
    I was going to lock the banjos down with the copper strip method and some blue Loctite....I'm not familiar with the BMW lifter, I take it that they can't be disassembled like a GM, and cleaned and re-installed?
    Any recommendations on lifters, I've found Ajusa at $6.50...INA at $10....
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    Can’t say for others, but I would stick with oem INA lifters. About $11 each from most retailers, compared to the $30 or so BMW oe lifters. Will also do all new INA lifters on my 850 during my valve stem seals project.
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Feb 2012
    Southern Ontario
    Quote Originally Posted by M6csi View Post
    Yes going with INA,
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Another source of potential tick would the the timing chain tensioner, on the v12 it can be adjusted. Hope this helps.
    Regards,
    Brian
    Cave Creek, AZ
  1. question about sticky lifter??
    By Sik wit it in forum 1991 - 1999 (E36)
    Last Post: 02-07-2009, 07:06 PM
  2. sticky lifter question with video
    By budget76 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-08-2008, 07:58 PM
  3. Sticky lifter question, with video
    By budget76 in forum 1991 - 1999 (E36)
    Last Post: 08-08-2008, 05:49 PM
  4. "Sticky Lifter" ???
    By P3RH4PS in forum 1996 - 2003 (E39)
    Last Post: 07-21-2008, 11:15 PM
  5. Sticky lifter/valve??
    By rodney817 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2008, 04:11 PM
