Results 1 to 6 of 6
Thread: Master Cylinder - Cast Iron vs Aluminum --> How to tell
    Jan 2012
    Vancouver, BC Canada
    1985 Mercedes 300SD
    So other than the obvious "look to see what metal its made of", is there a way to tell which one I have while its still on the car? I want to order a rebuild kit for it and need a way to definitively tell before I do.
    -thanks
    1983 BMW 733i My current project (or at least one of them)
    2003 Volvo V70 5 Speed Current Daily Driver
    1993 300TE 4Matic Project wagon -sold
    1997 E290 Turbo Diesel Wagon -traded for above, an amazingly comfortable car to drive, great drivetrain, but the rust, oh my god the rust
    1992 BMW 525i -traded in
    1990 Silver 300TE -Sold Loved the wagon, hated the M103
    1985 Grey 380SE Diesel Conversion, 2.47 rear end, ABS -Sold, really should have kept this one
    1979 Silver 300D "The Silver Slug" -Sold
    Mar 2013
    USA
    E21/early e23/e34
    If you can't tell by looking, try a magnet, aluminum isn't magnetic.
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Aluminum will be raw metal, while the cast iron part will most likely be painted black.
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
    Jan 2012
    1985 Mercedes 300SD
    Thanks to both of you Some how the entire magnetic thing slipped my mind. I'll also look for paint...
    Jan 2012
    1985 Mercedes 300SD
    Ok, never have I had this much trouble ordering brake parts for a car :S
    I have two options, a 7/8" master cylinder or a 15/16" master cylinder. The 7/8" specifies non ABS (my car doesn't have ABS), the 15/16" doesn't specify ABS or Non ABS....
    Any idea which one I need? Pulling my hair out here....
    Mar 2013
    USA
    E21/early e23/e34
    Run your vin through realoem, (last 7 of vin)- It'll tell you what the car came with and show the correct part number.
  1. Iron vs Aluminum LSx?
    By darkhorrus in forum Engine Conversions
    Last Post: 09-16-2012, 08:35 AM
  2. S50 vs. S52 Cams - How to tell the difference?
    By nick325xit 5spd in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-22-2012, 07:39 AM
  3. How to tell if master cylinder is bad (brake)?
    By jm01dc in forum 1992 - 1999 M3 (E36)
    Last Post: 01-31-2012, 01:39 AM
  4. How to tell a e36 M3 BRAKE MASTER CYLINDER FROM A 325
    By s14realm3 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 10-04-2011, 10:19 PM
  5. M52B28TU- Did America use cast iron or aluminum?
    By THEhomelessONE in forum 1991 - 1999 (E36)
    Last Post: 10-30-2009, 03:08 PM
