Results 1 to 16 of 16
Thread: Replacement torque converter
    May 2017
    Houston
    03' 540i, 05' 545i
    Greetings all.
    I am trying to prepare my pockets for this torque converter replacement I know is coming. Few questions:
    1. Any specific brand recommendations?
    2. How much should I be paying for this job? I've seen prices like 1400 floating around..
    Thanks in advance
    Jun 2017
    Indianapolis
    E39 525i
    Quote Originally Posted by bimmer7410 View Post
    Greetings all.
    Thanks in advance
    Do you own a 530 or 540? If you own a 540 i have never seen a torque converter fail on one of those. Only the 530i
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    His sig says 540.
    May 2017
    Houston
    03' 540i, 05' 545i
    Yep, I've got a 540. Strange that this issue doesn't seem to be common for the 540, as when I searched the issue on the 740 (which uses the same 5hp24) and found plenty of topics which describe my issue (grumbling sound at speed right before an rpm dip)
    They recommend a simple tranny fluid change + some Dr Tranny shudder fix. I think I'll try that route before going all the way on the torque converter..
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by DakodaE39 View Post
    True. Actually I'm not sure I've ever heard of a 5HP24 TC going out on any BMW or Audi. And I"ve known a crapload of those cars.
    I mean I'm sure its happened and probably some of my Audi buds have had it happen and I just didn't hear / didn't ask / just oldzheimers forgot... but... as a rule it seems the TC is not on your big worry list w/ those trannies.
    Last edited by geargrinder; 04-20-2018 at 11:42 AM. Reason: added quote for clarity
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    May 2017
    Houston
    03' 540i, 05' 545i
    This is super strange to me as well. AFAIK both the cars use the same transmission in most configurations and the problem is well heard of in their circle. I ran across a couple other 540 users whom never solved the problem
    Nov 2011
    Mel, Aus
    5series M62B44
    Something something 20,000km later of driving it like I stole it looking for a reason to import a manual. (With an Alpina trans tune)
    For all I know that stuff is snake oil, but it wasn't my first my first service of the trans.
    Very high chance yours has been serviced as well and the replacement filter is restricting flow causing the issues as well, that's a common fault with the 5hp24 with some cheaper filters. From memory filtrans? is the recommended filter.
    Cheers
    Mat
    Quote Originally Posted by hakhawk
    I know first hand that owning a bmw isnt what made hozy the way he is, its just his charm
    HoZY is good guy and has proven it many times by being a longtime participant in this community.
    Nov 2016
    Santa Cruz, CA
    2000 540i Touring
    5HP24 torque converter failure was/is very common on the Audi allroad. I think it was a seal defect that was fixed by around 2002 or 2003. Probably an Audi problem that doesn't apply to the 540i (I hope).
    Can't hurt to try a fluid change. I would talk to a ZF rebuilder/expert before trying additives.
    May 2017
    Houston
    03' 540i, 05' 545i
    Quote Originally Posted by msvphoto View Post
    Yeah ill be doing the fluid change very soon. Hopefully this week
    May 2017
    Houston
    03' 540i, 05' 545i
    I'd like to report back that the fluid/filter + dr tranny removed my issue entirely. Its possible that a simple change would have sufficed, but I did not think it was worth changing and still potentially having the issue.
    Its SO nice to be able to accelerate without that damned grumbling and stutter...now im gonna be even more obsessed with this thing. On to the catch-can install next...
    Mar 2010
    NICE!
    I think that's a good assessment and very likely. I don't know much about the AT magic snake oils, but I do know modern ATF's are some of the most high tech of fluids in the car and are loaded with all kinds of majicks already, and I think indeed just a flush or double flush would have done it (come to think of it, its similar to gas-additives, aka 'modern retail gas all contains that crap already'). But as long as there's no chance of harm, why the hell not. Hey come to think of it, I've tossed some of the liquimoly MoS2 additive in my tranny which is the manual equivalent of that so I guess I've done the same thing.
    2003 M3CicM6 TiAg
    Former:
    May 2017
    Houston
    03' 540i, 05' 545i
    NICE!
    Makes sense. I will repeat what has been said before: the lifetime fill is BS. Get that gunk outta there (if you're having a problem, that is)
    Now if only that darned manual swap wasn't so expensive
    Mar 2010
    Agreed but actually I'd actually say "get that gunk out of there BEFORE you have a problem!" Change that fluid from time to time while the transmission is working great and it'll last a LOT longer... And hell, it doesn't even have to be THAT often... every 60k or some is more than adequate to stay ahead of it and keep the parts protected by fresh goo.
    2003 M3CicM6 TiAg
    Former:
    May 2017
    Houston
    03' 540i, 05' 545i
    Completely agreed!
    Nov 2016
    Santa Cruz, CA
    2000 540i Touring
    Great news, glad it worked. Hope the shudder issue remains gone for you.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    There is a fair chance it was a restrictive aftermarket filter, bad seal from the filter to the pump or low fluid level that was the source of the problem. All of these will result in air-entrained fluid entering the torque converter.
  1. How to replace torque converter
    By onerepublic in forum 1995 - 2001 (E38)
    Last Post: 07-21-2019, 12:30 PM
  2. Replacing Torque Converter
    By 328ibills in forum 1999 - 2006 (E46)
    Last Post: 01-30-2018, 07:42 AM
  3. 00 740iL Replace Torque Converter or Transmission?
    By JackJones in forum Carolinas
    Last Post: 03-05-2015, 11:55 PM
  4. I need to replace Torque Converter. Upgrades??
    By BMWpartstrader in forum 1996 - 2003 (E39)
    Last Post: 12-16-2012, 08:13 PM
  5. Best source for replacement torque converter for M-sport trans?
    By machinemanjr in forum 1995 - 2001 (E38)
    Last Post: 11-15-2012, 11:03 PM
