Results 1 to 9 of 9
Thread: Noob help
    Apr 2018
    North Chesterfield, VA
    98 323i BMW Convertible
    Noob help
    I have a 98 323i Convertible I just started restoring and someone cut off my muffler while out, but just the muffler, I had no idea this was a thing but security had a code for it, well I'm finding it very hard to find a replacement muffler that isn't essentially a fart cannon, I did however come across this on eBay and my question is would this work on mine? It states 4cyl but idk if thats accurate or if it would even matter either way, any help, advice or links would be greatly appreciated
    https://www.ebay.com/itm/Fit-92-98-3...97.m4902.l9144
    Sep 2016
    Austin, TX
    1993 325i/5
    e36 4cyl motors have just one exhaust pipe, 6cyl have 2. you need to get one for the 6cyl
    Apr 2018
    Thats what has me scratching my head, mine is a single pipe after the cat-converter
    https://ibb.co/cdGrSS
    Oct 2013
    The Netherlands
    2011 E90 325xi
    Very possible. My understanding was that the 320i en 323i have an exhaust with only 1 pipe coming from the cat
    Apr 2015
    Tennessee
    1998 BMW 328i
    It should work. Make sure they didnt cut the mounting flange off on the other side though
    Nov 2017
    Adairsville GA
    1994 BMW 325is
    The 323is in particular have a different setup than normal on the downpipe, not sure about the exhaust. I helped my buddy score one. The downpipe is restrictive, and more power can be gotten pretty easily by swapping it out.
    You could likely just go with the downpipe/cat swap out and get a take off M3 exhaust. I got one for $80, pretty cheap. Never got around to putting it on.
    **Update** Found this link for ya...
    https://www.bimmerforums.com/forum/s...nce-Mods-323is
    Jan 2018
    Earth
    Any one of those ebay systems isn't going to be anything less than a fart cannon. If you want to maintain the noise level that you had on your stock/stolen muffler, get an ANSA which is decent quality, quiet and reasonably priced.
    Nov 2007
    Central IL
    E36
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Nov 2007
    Central IL
    E36
    Just find someone parting out a similar car.
    323's had a single exhuast post cat. Use Realoem.com to look at diagram...
    http://www.realoem.com/bmw/enUS/show...diagId=18_0189
    You can use entire exhaust from a 325, 328, or M3, but will need it from the manifolds back:
    Something like this:
    https://www.ebay.com/itm/DUAL-3-MUFF...xagk6Y&vxp=mtr
    Or again find it used, just make sure it comes with cat back and midpipe. All (US) 6 cylinder exhausts mount up to the same spot at the manifolds.
    1995 M3
  1. noob help with exterior 'trim'?
    By jstretch in forum 1999 - 2006 (E46)
    Last Post: 09-15-2006, 10:39 PM
  2. Noob Help
    By colemanpaiva in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-25-2006, 06:12 PM
  3. noob, help please
    By deadweight in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-24-2005, 12:34 AM
  4. Noob help with E30
    By mikei in forum 1983 - 1991 (E30)
    Last Post: 07-22-2005, 02:02 PM
  5. Audio Noob...help!
    By Black328iS in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-25-2004, 05:19 PM
