I've got an Active stage 3 FMIC that has never been used. The intercooler was built with a Spearco core, custom end tanks and e36 M3 mounting brackets. I'm asking 500$ or best offer. Let me know if you need more pictures or have any questions.
https://imgur.com/xJlOBim
I’m unfamiliar with this intercooler and didn’t find anything on google. Core size? Inlet size? With rear exit does it keep the factory brake ducts? Also looks thicker than 3” assuming would have to replace oem fan to fit.
The core size is 18.5 x 10 x 4.5" and the inlet size is 2.5" That's correct it doesn't interfere with the factory brake ducts and you also do not need to replace your factory fan to fit. You do however have to trim the bottom edge of the aluminum bumper beam to fit the intercooler though.
Badass intercooler and the best seller
1989 535i - sold
1999 M3 Tiag/Dove - sold
Might be interested in this place shipped 91701? Thanks.
I'm struggling to use this forum lol. Please shoot me a text with your best price so I can possibly invest in a good intercooler 9099212209
Is this thing still around? What's the deal?
