RM European Auto Parts
Results 1 to 2 of 2
Thread: M20B25 head bolt reuse?
    Apr 2014
    gold coast
    97 e36 323i executive
    Hi there
    I have recently put a new head onto my m20 block and torqued the bolts on, half way through doing the bolts i realised that the angle gauge i was using wasn't working the way it was suppose to. my question is this, i know that head bolts are one use only but due to the engine have not being turned on and the bolts not heated/ cooled can i loosen them and restart the torquing sequence? or do i need to buy another set? thanks
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    If you were into the final angle torque stage, you must not reuse the bolts. If you were on the first 90 degrees, you should be fine reusing them.
    Chris Powell
    BMWCCA 274412
  1. Reuse cut down head bolts......
    By Bill837 in forum 1991 - 1999 (E36)
    Last Post: 09-06-2016, 07:30 PM
  2. Reused Factory/Stock Head Bolts!
    By M3Scharged in forum Forced Induction
    Last Post: 11-12-2007, 09:22 AM
  3. head bolt torque spec/procedure?
    By CrzyLiki in forum 1991 - 1999 (E36)
    Last Post: 03-12-2003, 01:12 AM
  4. Broken Head Bolt on M50 Engine!!
    By sbcncsu in forum 1991 - 1999 (E36)
    Last Post: 08-26-2001, 03:23 AM
  5. Broken Head Bolt on M50 Engine!!
    By sbcncsu in forum 1988 - 1996 (E34)
    Last Post: 08-25-2001, 10:39 PM
